Wanted: Safety Valves (2) 5/16 - 27 tpi
Hello everyone, I am on the hunt for a couple of safety valves, would like the ones pictured but at the very least ones that are threaded 5/16 - 27 tpi (male)
Thanks all!
-David
Thanks all!
-David
Re: Wanted: Safety Valves (2) 5/16 - 27 tpi
Air or steam?
It looks like a valve originally designed for air..because of what appears to be the single outlet at right angles to the inlet.
Steam valves generally are not constructed in that way.
Pressure settings...release / reset?
I need steam...boiler pressure is 80...so 2 and 2 over that respectively for blowoff I believe..
Thanks Bill.
Thanks Bill.
Hello David;
What are you running these on ? I have models of Consolidated safety valves available... Please send a PM and we can discuss your application.
Dave Bortz
Superscale
Dave Bortz
Superscale
Those are beauties! Ok I will DM you.
Thanks Dave.
Thanks Dave.
Forgot a couple details.
This is for a 3/4" scale Northern
The safety valve pictured I got from a live steam supplier but can't for the life of me remember where...
Take a look at these from Eccentric Engineer.
https://www.eccentricengineer.com/safet ... ale-safety
They'll be a little big, but better than anything else out there (edit) for 3/4" scale.
John Brock
Thanks John..
Might be a bit large; sure nice though!
-David
-David
Can you post a photo of a ruler next to your pops?
I suggest the Eccentric Engineer pops. He can make adapters to suit your specific size. They are actually rather compact, might be the same real estate as your pictured pop, or smaller... And they look GREAT too!
Thanks Mike,
I will try to get a photo posted a bit later.
Thanks for the suggestion!
-David
-David
- Joe Tanski
Take a look at circle seal relief valves series 500 brass or stainless 0-200 psi ,with Viton seal for steam,they will set them to what pressure you
Require 1/8 not on up threads
They work great nice and small in size have then on my one inch hudson.
Joe
Joe
Ok thanks Joe!
