I have a modern FP5 glad hand, with hose and the male threaded fitting on the rear, its a modern complete FRA approved set for intrchange, and its in good condition.
I need an old style small hose (pre 1962 style) FP5, the one that has the pin brazed into it, to prevent overrotation. Rust covered is fine.
The only important condition is that its wear surfaces are still well within tolerance. I just a really good clean straight one to scan, not to use.
I also need a tapered plug angle cock, again it need not work, so if you have one that leaks that would be great, it just needs to be a pre 1950 model.
Loco112
FP5 glad hand (pre 1962 style) , plug angle cock, needed
