What should i do to start restoration
This forum is for Internal Combustion Engines such as Hit 'n Miss, Throttle Goverened One Lungers etc. Repair, Machining, Operation, Buy/Sell/Trade of these engines are all topical.
versatile
Post by versatile » Tue Mar 08, 2005 5:06 pm
I have an old single cylinder stationary engine. Twin flywheels etc and water resivoir to cool it. No idea what brand. Rusted up and froze up from sitting outside for 35 plus years. How do i start? Should i soak the whole thing in something or what should i do?
CD_Smith
Re: What should i do to start restoration
Post by CD_Smith » Wed Mar 09, 2005 1:48 pm
I soaked mine in liquid wrench for about a month and then slowly started twisting the nuts and bolts. Complete success. No broken bolts. I used about two quarts of liquid wrench. The piston took the most effort and I did break one of the rings or it may have already been cracked. I drove the piston out with a four pound hammer and lots of 2x4's and liquid wrench. It took me about one week to get the piston out. For a replacement ring I discovered that Detroit Diesel 1200 hp engines had the same bore as my engine but the rings were half as thick therefore I placed two rings in the same slot. I still need to grind the valves but as it sits the compression is not great but ok.
steamin10
Post by steamin10 » Sun Mar 13, 2005 9:12 am
I use diesel fuel to soak into long rusted parts, it penetrates well by itself. A few little taps on the bolts and covers and joints, will help loosen the joints. Use a small sledge 2-3 lb to gently rap on the pieces without breakage. These soundings will loosen most anything.
