one piston heat engine tips
Any one have tips for building one piston heat engines,glass metal, or others.
you cant get there from here
Single piston heat engine
Try this web site http://www.stirlingengines.org.uk/ Browse around and you will find pictures of the single piston engine that use a test tube and a bit of scouring pad for regenerator. Is this what you are looking for? If so send me an Email, I will send you a picture and specs. of one i have built. It runs along a good speed. Lynmn
Plans make it easy to build an engine. I have an original sterling engine built about 1915. I spent 2 weeks making detailed drawings of the fan and all the parts. I have used the plans to build 3 more hot air engines. Each one is a little different but the basic 2" bore engine is the same.
http://www.youtube.com/watch?v=J56D56rQV-Q&NR=1
http://www.youtube.com/watch?v=NBpRl5eF ... annel_page
http://www.youtube.com/watch?v=57GFrxz_ ... annel_page
http://www.youtube.com/watch?v=iSBXcn4u ... annel_page
