Wood Refrigerator car ladders
Moderators: Harold_V, WJH
FLSTEAM
Post by FLSTEAM » Wed Oct 02, 2019 3:45 pm
Does anyone have drawings or photos of the ladders used on narrow gauge reefers?
I would like to model them but would like more info on their construction and mounting.
John B.
http://www.ngshay.com/
Shay drawings and castings
makinsmoke
Re: Wood Refrigerator car ladders
Post by makinsmoke » Wed Oct 02, 2019 5:47 pm
Branchline?
makinsmoke
Post by makinsmoke » Wed Oct 02, 2019 5:52 pm
Course D&RG and RGS (and C&S) used grabirons, not ladders, John.
FLSTEAM
Post by FLSTEAM » Wed Oct 02, 2019 6:47 pm
RGS had them...…The picture I have looks like two runners with pipe rungs using straps to hold each rung.
JB
jeffsmith
Post by jeffsmith » Wed Oct 02, 2019 7:02 pm
I have castings available for built up ladders using 3/16" brass angles. Here is a photo of the finished ladder with the castings on the top and bottom of the brass angles. The castings are a left and right.
Jeff
Branchlineproducts.com
FLSTEAM
Post by FLSTEAM » Wed Oct 02, 2019 8:09 pm
What scale? How much do they cost?
JB
jeffsmith
Post by jeffsmith » Thu Oct 03, 2019 9:42 am
They are 1.5" scale and $2.50 each.
Jeff
FLSTEAM
Post by FLSTEAM » Thu Oct 03, 2019 11:17 am
Exactly what I want. However the car I am building is 2 1/2" scale.
JB
makinsmoke
Post by makinsmoke » Thu Oct 03, 2019 9:33 pm
Hi John,
Apologies. Yes, the RGS reefers (ex C&S) used ladders.
And steel frames and Bettendorf trucks!
Here’s a Dave Dye photo of C&S 1113 at CRRM:
http://davesriogrande.net/Rosters/CS/CS_1113.htm
Take care,
Brian
makinsmoke
Post by makinsmoke » Thu Oct 03, 2019 9:39 pm
Looks like angle iron. The tops had the side angle cut off and the flat bar bolted to the top side boards. The bottom looks like another piece of angle bolted to the angle and the car side.
If you can mass produce the grabirons this should be pretty easy to make.
Any construction pics???
Brian
makinsmoke
Post by makinsmoke » Thu Oct 03, 2019 9:41 pm
If it’s a C&S or RGS car the door latches are nothing like the D&RG jobbies. Again, pretty rudimentary. Would be an interesting detail that would grab people’s attention.
Post by Glenn Brooks » Sun Oct 06, 2019 7:56 pm
Seems like you could make these out of 1/2 or 3/4” bar stock with welded drill rod across each side, for the rungs...
