Show us your ET (electric train)
Moderators: Harold_V, WJH
BigDumbDinosaur
Re: Show us your ET (electric train)
Post by BigDumbDinosaur » Wed Feb 03, 2021 12:47 pm
I think you need to "isolate," not insulate. Strategically placed bulkheads, along with suitable fans, should keep the battery compartment temperature from becoming excessive.
Something I use in my F7 (not battery-powered) to get rid of engine room heat is a 92mm box fan that has an integral temperature-sensing feature. There is a thermistor that is exposed to the air stream and an internal controller that changes the fan's speed according to temperature. At room temperature, the fan runs slowly and uses very little power. You can get the fan from Digikey Electronics. I also attached the data sheet (PDF) and a pic of one of the fan assemblies from my F7. The right-hand view shows the thermistor.
F7 Cooling Fans
Here's the data sheet for the fan:
mechatronics_e9225.pdf
(322.18 KiB) Downloaded 94 times
All that said, temperature rise is more a concern with lithium batteries than with lead-acid. I have to wonder if compartmentalizing your batteries and force-air cooling them will accomplish anything of value.
Research is what I'm doing when I don't know what I'm doing.
Atkinson_Railroad
Post by Atkinson_Railroad » Wed Feb 03, 2021 3:57 pm
Yes, “isolate” would have been a better word Bill.
And yes, a little blower motor to circulate air would draw very little current on a bank of lead acid batteries.
That’s a useful option to consider if there is even a reason to.
In an effort to stay on message with -Show us your ET (electric train)- I’ll share a partial diagram of our Lima Switcher as my
contribution to this thread. I have always wanted a more detailed diagram of the engine showing all of the actual connections
and have yet to complete the cab portion of the electrical schematic. It’s a challenge to stay up-to-date with everything related
to a railroad at times. This particular drawing in the hands of any savvy electrical person provides a trail to follow instead of
having to dig and trace a problem when electrical issues occur.
Someone has noted, “Where’s the electronics?” Well, there is no electronics. It’s pretty much a very simple Zero or One and that’s it.
It’s purposely drawn on paper because I don’t want anyone to have to rely on electricity to read it.
Keep up the passionate work folks. It is fun to look in once in the while to see what’s going on.
John
Hero
Post by Hero » Fri Jun 11, 2021 1:48 pm
Just saw this thread.
Here are my matched 7.25" gauge steeplecab locomotives, driven by four 12v automotive batteries powering salvaged 12/24v tape drive motors.
https://youtu.be/kbLaHU6M_xY
Maybe someone will like them. I do....
Erskine Tramway
Post by Erskine Tramway » Sat Jun 12, 2021 10:09 am
I just noticed this thread too. Here's 'Sparky', my 7-1/2" gauge tram loco. He's built on a Ride Trains 'Mini Motor Car'' chassis, with a wooden body. One 24 volt motor and two Interstate batteries with chain drive to both axles. Speed control is by a Syren50 controller, with manual control. I charge the batteries with a dual output battery conditioner.
Sparky has a bicycle clasp brake on one wheel, with a Range Rover emergency brake ratchet handle.
Mike
Former Locomotive Engineer and Designer, Sandley Light Railway Equipment Works, Inc. and Riverside & Great Northern Railway 1962-77
BN RR Locomotive Engineer 1977-2014, Retired
Hero
Post by Hero » Tue Jun 15, 2021 5:48 pm
"Sparky" is a real dandy. Is that track a home track or a club track?
Erskine Tramway
Post by Erskine Tramway » Wed Jun 16, 2021 8:35 am
That's my home railroad, the Erskine Tramway. It's 845 feet long, out across the pasture.
Your steeple cabs are very nice too.
Mike
