Anybody recognize this old one cylinder mystery engine?
Hello all, starting to assess the possibility of restoring this old 1959 built 12" ga 1500 yard switcher. It has a one cylinder, apparently air cooled engine with a largish expansion tank on the front end, and a multiple gear manually operated transmission on the port side. On the starboard side, the motor has a hand crank out the side of the engine, which spins the cylinder two revolutions then 'clicks' the distributor on the third revolution. Painted dark blue, for what that's worth.
Does anybody recognize the motor? I guess one possibility is it is an old hand farm engine mounted sideways in the loco frame to allow the transmission/ gear box to align the chain drive to the front truck. So far we haven't found a manufacture plate or casting mark to identify it. Also can't get into the body of the loco to look closely without cutting rivets or pulling the motor. I would like to try to get it running in situ, if possible, without pulling it all apart and breaking stuff - u till I have some idea what the make and model is...
Hoping someone will recognize the parts or configuration and be able to offer some idea of make and model.
Also would like to be able to research/order parts and maybe score an rebuild Manual, etc...
Thanks much,
Thanks much,
- Attachments
Last edited by Glenn Brooks on Wed Jun 08, 2016 10:11 am, edited 3 times in total.
Re: Anybody recognize this old one cylinder mystery engine?
Here are a couple more photos of existing parts on the motor.
- Attachments
Glenn,
Pretty sure that is a Wisconsin engine with a hand clutch mounted up to it. Thats a magneto ignition and the clicking is the impulse coupling. Gives a snap action for a hot spark so there isn't much effort needed turning over the crank. Impulse coupling drops out after starting. Plenty of Wisconsin info out there. Looks like it has been sitting for quite some time. You've got a project on your hands for sure.
Bob
Bob
3/4" Juliet II 0-4-0
3/4" Purinton Mogul "Pogo"
3/4" Hall Class 10 wheeler
3/4" Sweet Violet 0-4-0
3/4" Hunslet 4-6-0
1 1/2" A5 Camelback 0-4-0
3/4" Hunslet 4-6-0
- steamin10
The idea of 'just getting it running' is a dark road for an antique piece, and is responsible for the destruction of more running pieces than time itself. At minimum get down to the cylinder, and make sure the rings are not stuck, and you have a clean bore to run with. Without that, destruction of piston or bore will spell doom to the operating ability you may have. Magneto ignition is quirky, and old ones fail. But take heart, there are many sites and a few guys that can rebuild these tings, and restore function. Fuel,spark, and compression, you got it all.
Of course paint is pretty, and a labor of love on an old piece, that makes a mantle decoration out of a dead engine. I encourage you to start with making the internals good before anything else.
Thanks guys, yep, it's been stored in a shed for at least 25 years. It turns over easily with the hand crank, but that's as far as I've taken it so far. Right now, just trying to identify what it is, then go look for a parts manual and spares, etc.
I left it outside this winter to let the rain accelerate the process of stripping the old paint off the body.- it's all galvanized with very little rust.
Big Dave, Iam with you re: tearing down and looking at the internals. But so far, don't want to be taking stuff apart, until I have some idea what it is, mainly so that if something breaks during dissemble I will know where to search for replacement pars. And also need to know how to put it back together! " oh yah, I will remember which nut and bolt this is" doesn't work so well as it used to...
I saw some Wisconson Model AED photos on line today that seem similar. So maybe on the right path.
I would concur that it is a Wisconsin engine. Probably an AEN, AENL, or AENLD. All good heavy duty engines. You said it turned over without any difficulty. Does it seem like it has compression? Wisconsin's have a tendency to have the valves stick open if put away for an extended period of time without some oil being put in the cylinder and turned over by hand a few times before being stored.
You should hear the impulse coupling snap at the top of each compression stroke. If there is no spark, check that the points in the magneto are not stuck open or pitted so bad that they will not pass current when closed.
Have fun.
Karl.
Have fun.
Karl.
- warmstrong1955
Looks like a Wisconsin to me too!Karl_Losely wrote:I would concur that it is a Wisconsin engine. Probably an AEN, AENL, or AENLD. All good heavy duty engines. You said it turned over without any difficulty. Does it seem like it has compression? Wisconsin's have a tendency to have the valves stick open if put away for an extended period of time without some oil being put in the cylinder and turned over by hand a few times before being stored.
Have fun.
Karl.
I resurrected several that were mounted on some skids with snail fans. (Small centrifugal fans for mine ventilation)
And yes....these things were stored both outside and inside, and all but one out of six, didn't have valves that were stuck open.
Thanks all for helping identify the motor. Haven't dug into the engine yet - to many unfinished projects taking up shop space. But intend to get started soon as some track laying gets finished this month.
Anyone know of a vendor that rebuilds these old Wisconson carbs these days? Or the magneto??
now is the time for a tablet/cheep phone and make sure you take pics of everything as it comes apart every step of the way.
that 20.30 dallor phone will be a life saver down the road. i concur on the brand and advice to make sure nothing is stuck, gummed up etc before a run test.
Yep, absolutely. Pics every step. I even know of a guy who bags and tags all the nuts and bolts, with notes on slips of paper to describe where everything goes back together. Wish I was that organized...
