Reversing Switch/Relay for 24V Electric
NCBQGUY
Post by NCBQGUY »
I bought a 24V Centercab 0-4-0 critter that has a nicely done beefed up homemade version of a Mr. Motion drive based on a Schwinn bicycle motor and controller.
Because bikes don't have much need for a reverse the builder provided a simple DPDT bat handled switch for reversing....mounted on the underside of the frame which would be a little inconvenient for switching.
Does anyone have any suggestions for a different setup that would be compatible with control with R/C components? I would like to avoid R.Goldberg setups if possible as I don't want bits that can go out of alignment in service.
Charlie Vlk
DianneB
Re: Reversing Switch/Relay for 24V Electric
Post by DianneB »
On my 7.5" gauge streetcar I used a 1KW electric scooter controller which didn't have reverse so I added a couple of 12 volt automotive relays (with the coils wired in series) controlled by a small toggle switch. (Relay: http://www.ebay.ca/itm/like/13185437049 ... dispItem=1) The inexpensive and reliable relays reverse the polarity to the motors. Works like a charm.
If the coil current is too high for your R/C equipment, you could add a small relay to switch the power relays.
FLSTEAM
Post by FLSTEAM »
As Dianne said you could also just use a single spdt 24v relay and an R/C relay. The power relay would be wired to forward as default.
John B.
Atkinson_Railroad
Post by Atkinson_Railroad »
Google "H Bridge Relay Circuit".
You'll find plenty of ideas, including connection diagrams.
URL Reference: https://www.google.com/search?lr=&as_qd ... ibgPS-DRHA
John
DianneB
Post by DianneB »
FLSTEAM wrote:As Dianne said you could also just use a single spdt 24v relay and an R/C relay. The power relay would be wired to forward as default.
John B.
Afraid not. You need a minimum of TWO poles 'cause you need to reverse the connections between the motor and the controller.
FLSTEAM
Post by FLSTEAM »
Sorry about that, you are correct...should have read DPDT 24V relay.
I didn't have my brain engaged before typing.
John B.
NCBQGUY
Post by NCBQGUY »
Thanks for the replies.
Turns out this was covered in a current thread where a Dimension Engineering Syren50 controller was recommend.
On the linked diagram there are components pictured and in the wiring diagram that are not identified. It would be helpful to know what everything is and what the specs are for each part and what voltages are in each part of the wiring.
Anyone have experience with this unit? It looks like it may be just what I am looking for....
Charlie Vlk
Fender
Post by Fender »
Charlie,
A DPDT contactor (with the non-energized position for forward) is exactly what I use on my Davenport electric loco. One cautionary note though: don't reverse the engine while under power, because the contacts will arc and then reverse won't work anymore. Ask me how I know this.... :x
Chattanooga, TN
SteveM
Post by SteveM »
Just be sure you use stuff rated for DC.
You might see switches / relay contacts rated for adequate amps at 110 or 220 VAC, but AC is not the same as DC. Because AC is constantly switching polarity, when the contact breaks, it stops arcing. DC doesn't do that.
skid-roe
Post by skid-roe »
https://www.ebay.com/itm/10-30V-100A-30 ... 2749.l2649
Check out eBay,
I purchased a 24 volt 100 amp reversing PWM motor controller for $55
SteveM
Post by SteveM »
skid-roe wrote:https://www.ebay.com/itm/10-30V-100A-30 ... 2749.l2649
Check out eBay,
Interesting. Does it have dynamic braking?
Also, do you know if there is a user manual online?
steamin10
Post by steamin10 »
Note to Steve M.
In my experience working on relay circuits, one way to shut down arcing from coil field collapse is to increase the air gap on the contacts. This is easily accomplished by using multiple contacts on the switch block, wired in series, so that opening multiplies the speed of the gap appearing in the circuit. This is general information but can be cheaply effective with surplus relays of various types. In battery powered circuits, remember not to build in holding designs that waste power. Rather build in default positions (Run, Forward) as default to return at shutdown.
