New signs from Odd Duck Foundry
Posted: Sat Apr 07, 2018 8:40 pm
New from ODF! At the risk of incurring the wrath of their lawyers, I am tentatively calling these "Hershey Bar" signs. This is because they are going to be cast in "bars" that the end user can cut apart as needed, as you can see in the first pic. They are roughly right 1/8th scale. Along with what you see, I am also going to be making a variation for the diamond and oval sign, replacing the "W" with an "X", this should cover the majority of railroads, methinks.
All of them are going to be post mount on the back, all that will be needed is a hole drilled for the size of rod you will be using. I'm about halfway through the pattern process, need to clean these castings up to make the permanent matchplates with. Price to be determined at a later date, probably between $10 and $15 per bar.
