SD-45-T2 drawings
Moderators: Harold_V, WJH
Railroaddaddy
SD-45-T2 drawings
Post by Railroaddaddy » Mon Dec 31, 2018 3:24 pm
I want to build a 1.6 scale SD-45-T2 locomotive.I am searching for any blueprints that are available.
Thanks Bob
ERIE S-1 BERKSHIRES
Re: SD-45-T2 drawings
Post by ERIE S-1 BERKSHIRES » Wed Jan 02, 2019 6:54 pm
On page 149 of Model Railroader cyclopedia volume 2 diesel locomotives, is a good side view front and rear line drawings, I hope this will help you
rkcarguy
Post by rkcarguy » Thu Jan 03, 2019 12:40 am
If you can't find anything with dimensions, I don't think it would hurt to buy a quality HO scale model and a set of cheap machinist calipers, and start scaling it up. That's what I did for my Baldwin S-12 I'm working on, plus I used what few dimensions/drawings I could find online as "check" dimensions.
In my case our local train show provided a $10.00 Athearn Blue Box S-12, it was right on except the hood width was wider to fit the electric motor, and it turned out to be a blessing because my Honda GX390 and hydraulic drive setup will just barely fit.
davidqueener
Post by davidqueener » Sat Feb 09, 2019 1:53 pm
Please contact me offline, and I think I can help you with some prototype drawings.
Dave Queener
Pastor, St. Paul Presbyterian Church
www.StPaulPres.com (865) 209-5654
Owner, Cumberland Model Engineering
www.CumberlandModelEngineering.com (865) 333-5712
