Re: Train detector, welded rails - ideas???
Posted: Wed Feb 20, 2019 11:26 am
I like John Haslers idea, yes the LED's may get dirty, but because these are infrared I think they have a certain amount of "penetration" and everything doesn't need to be perfectly clean. Our garage door sensors are buried in cobwebs for instance, and still work. Wire as many of them as you need to control the section of track, add a relay to control a 2 aspect signal and you're there.
As for the LED layout, if you arranged them in a long angle back and forth across the track as many times as needed, nothing is going to slip by.
