Wood Refrigerator car ladders
Does anyone have drawings or photos of the ladders used on narrow gauge reefers?
I would like to model them but would like more info on their construction and mounting.
John B.
John B.
- makinsmoke
Re: Wood Refrigerator car ladders
Branchline?
- makinsmoke
Course D&RG and RGS (and C&S) used grabirons, not ladders, John.
RGS had them...…The picture I have looks like two runners with pipe rungs using straps to hold each rung.
JB
JB
I have castings available for built up ladders using 3/16" brass angles. Here is a photo of the finished ladder with the castings on the top and bottom of the brass angles. The castings are a left and right.
Jeff
Branchlineproducts.com
Jeff
What scale? How much do they cost?
JB
JB
They are 1.5" scale and $2.50 each.
Jeff
Jeff
Exactly what I want. However the car I am building is 2 1/2" scale.
JB
JB
- makinsmoke
Hi John,
Apologies. Yes, the RGS reefers (ex C&S) used ladders.
And steel frames and Bettendorf trucks!
Here’s a Dave Dye photo of C&S 1113 at CRRM:
http://davesriogrande.net/Rosters/CS/CS_1113.htm
Take care,
Brian
Take care,
Brian
- makinsmoke
Looks like angle iron. The tops had the side angle cut off and the flat bar bolted to the top side boards. The bottom looks like another piece of angle bolted to the angle and the car side.
If you can mass produce the grabirons this should be pretty easy to make.
Any construction pics???
Brian
Brian
- makinsmoke
If it’s a C&S or RGS car the door latches are nothing like the D&RG jobbies. Again, pretty rudimentary. Would be an interesting detail that would grab people’s attention.
Seems like you could make these out of 1/2 or 3/4” bar stock with welded drill rod across each side, for the rungs...
