Hi Folks,
I make banjos and I have developed a "coordinator rod" system that requires a 5/16 X 18 thread on a 5/16" brass rod. The rod should 12" long and the threaded portion is on the end, one inch long. There are other tasks, but I can do them myself. I have been using a die, but my threads are not always cut parallel to the rod. I think they would be better done on a lathe.
I am inviting you to quote on small runs 10 pieces would be ideal. I can go to 25 pieces if I must. If you need the material I can ship it to you.
I have enclosed a drawing and if you want to see how the item is used, go here. http://www.hicklerbanjo.com/faq.html#131886
Thank you!
Mark Hickler
Hickler Banjo LLC
hicklerbanjo@gmail.com
480-276-8294
Small Run - Simple Threading Job
Re: Small Run - Simple Threading Job
Mark,
You have a PM.
Jack.
You have a PM.
Jack.
Jack,
I tried the technique you described and got excellent results. Thanks very much!
- Mark
- Mark
HI MARK,
Glad I could help.
Wait a minute, looks like I just screwed myself out of a job.
Jack.
Glad I could help.
Jack.
