Need motorcycle Piston machined please.
This forum is for those individuals or small business to solicit requests for Service from those members of our group. Machining, Foundry work, Sheet Metal work etc. This site makes no guarranty of work or represenation by the users of this site. It merely attempts to provide a place to allow individuals the opportunity to meet and discuss needs and capabilities.
Otis0
Post by Otis0 » Tue May 06, 2014 3:31 pm
Hello, thanks for looking at my problem.
I have 250cc Yamaha motorcycle engine that I want to put 350cc Yamaha cylinder on.
I am looking for a machinist to change the -Yamaha ymf350- piston pin, or wrist pin bore from-- 19.00 mm i.d.-- to 20.00 mm. i.d.
I know that this has been done before, as the swap is documented online. The only hard part is getting piston machined for 1mm. larger pin.
I will send piston + pin. Let me know what you want to do it.
Thank you Otis0
home-machinist
Re: Need motorcycle Piston machined please.
Post by home-machinist » Tue May 06, 2014 8:08 pm
hi, I can help you. email me . afterworkhomemachinist@gmail.com.
