Pros and cons of larger chucking machine reamers V. Boring bar
Glenn Brooks
Post by Glenn Brooks »
I have 25 to 30 6" diameter cast iron RR wheels that I need to turn for 1" ID axles. Maybe 1.25" ID, haven't decided final axle size yet.
Are there any deal breaker issues with drilling and reaming the holes in the wheels with a 1.0" machine chucking reamer, versus boring to size with a boring bar?
I haven't bought the reamer yet, but found some good prices on NOS 1" and larger reamers, which I could order - if this is a feasible procedure on a manual 14" lathe.
Thanks
Re: Pros and cons of larger chucking machine reamers V. Boring bar
Frankly, I wouldn't ream even if I owned the required reamer. I'd bore, and for more than one reason.
One of the issues you'll face with a reamer is alignment. As large as this one would be, it won't be forgiving of misalignment, which is very common in lathes. It can yield various problems, none of them to your benefit. Taper is one of them, as is out of round. It also may or may not cut size, with the likelihood being better that it will if you ream only a few thou. That, of course, would depend on alignment, once again, or if you use a floating reamer holder.
One more thing to consider. Drilling and reaming often yields eccentric holes. Boring, even if followed by reaming, is highly recommended. By making that decision, you can leave just a few thou (no more than five) for the reamer. The less material you remove, the better the chance the reamer will cut on location, and size. A damaged flute on a reamer, accompanied by an excessive amount of material to be removed can often result in the reamer being deflected, creating an oversize (bell mouthed) hole, which gradually returns to proper size as the reamer deepens in the hole.
From the above comment, you likely understand that a reamer has the capability of yielding various sizes, often in the same hole. Not suggesting that it would in your case, but it's one of the things you need to keep in mind. Also, assuming it yields a tapered hole, if you're relying on a press fit, you may or may not end up with one, or it may have enough taper to permit the wheel to walk on the axle. All in all, boring, done properly, is heads and shoulders better. It's just slower, and demands a little skill on the part of the operator.
Glenn Brooks
Thanks Harold,
Good comments, as usual! I'll stick with my boring bar and save the sixty bucks.
SteveR
Post by SteveR »
Harold_V wrote:One more thing to consider. Drilling and reaming often yields eccentric holes. Boring, even if followed by reaming, is highly recommended. By making that decision, you can leave just a few thou (no more than five) for the reamer. The less material you remove, the better the chance the reamer will cut on location, and size
So in the interest of productivity, drilling is faster than boring - if I drill to 15/16, then bore this to 63/64, then ream to 1.0000 what is your thought on this?
1) In the context of train wheels for the live steam hobby?
2) In the context of best possible?
Always trying to learn.
SteveR
Not enough measuring tools...
1" FEF in progress
1" & 3/4" LE Projects
Measure twice, cut once, wait - it was supposed to be brass! :)
My thoughts are no different. If you wish to ream, make sure boring is part of the equation, which guarantees concentricity. It also allows one to choose the amount of material remaining to be reamed. My comments in the previous post should help make that clear, but I'd most likely leave less than .015" for the reamer. Probably more like .005".
So readers understand, I'm not a huge fan of reamers. They work reasonably well in many circumstances, and they're certainly faster than boring, but the negative attributes (bell mouthed holes, out of round (multi-sided) holes and tapered holes, plus the odd poor finish, for me, make them less than desirable. That, of course, depends on the application. I really like them for working with dowel pins, and I keep sets on hand that are known to yield the desired fits. I also used a 3/8" chucking reamer when I ran the face plates for the light switches in my new house. Over 100 holes, which accepted the Delrin push buttons, were reamed with excellent results, but I had to use an extraordinary feed rate (ran the face plates on my Hass CNC toolroom mill) in order to avoid chatter at the entrance, and to achieve a desirable finish. The holes (and the face plates) turned out exceedingly well. Clearly one of the times a reamer was a good choice.
AllenH59
Post by AllenH59 »
How "centered" do the holes need to be? If the error allowed is greater than the error of your chuck, you could drill them all to 63/64" or something like that, then set up to do one or two boring cuts on each and just cut to the numbers once you get going.
Benta
Post by Benta »
Just the material makes me shudder. Reaming in cast iron is no fun. Single pointing with a boring bar is by far the best and most controllable option.
warmstrong1955
Post by warmstrong1955 »
I like reamers.
Fab shop down the road used them all the time.
Then they cut new parts, or welded up the bores they messed up, and brought them to me to bore on my mill, to hold a tolerance, and keep the world aligned.
Unfortunately....they bought a machine shop of their own....and bore their own stuff now....
Bill
SteveM
Post by SteveM »
When I did a set of wheels, I found that there was a misalignment between the headstock and the tailstock and ended up with the tapered holes of which Harold spoke.
Solution was to put the wheels in soft jaws and bore them out slightly larger, which worked out perfectly.
On a drill press, where you aren't going to have an alignment problem (the original hole and the reamer will be concentric as long as you don't move the workpiece), you may see better results, but on the lathe, the misalignment will get you (and there WILL be misalignment - only a matter of how much).
BadDog
Post by BadDog »
I would suggest that there is likely going to be misalignment even without moving the piece, on drill press or mill. Spindles have runout, and drills "wing" a bit when starting, and don't drill straight. This can be largely mitigated by using starting drills, short drills such as "screw" length, new or (quality) machine sharpened bits, starting bores, etc. But one axiom of machine work is "everything moves". Perhaps not enough to matter, but at some level of precise measuring, things move. The key is to get below the tolerance allowed, and that may happen when drilling and subsequently reaming on any machine using appropriate prep and techniques. But I think it would be a mistake to assume that drilling and then reaming without moving a part (mill, drill press, or other) would automatically produce a bore without undesirable characteristics.
For many of my common uses, a brace and dull hand ground bit drilled horizontally and applied while hopping on one leg would generally yield acceptable results. For critical holes in the tiny super high tolerance parts that Harold used to make for missiles, I doubt any level of skill and tooling would be able to produce holes that consistently meet requirements using only drill and reamer (opinion based on Harold's previous comments).
