Slitting saw
John Hasler
Re: Slitting saw
Post by John Hasler » Mon Mar 12, 2018 7:54 am
I read everything you write.
toddalin
Re: Slitting saw
Post by toddalin » Mon Mar 12, 2018 1:24 pm
stephenc
Re: Slitting saw
Post by stephenc » Tue Mar 13, 2018 11:46 pm
Earlgo
Cut off wheel .... great idea , worked perfectly .
earlgo
Re: Slitting saw
Post by earlgo » Wed Mar 14, 2018 8:56 am
Glad to hear it.
That technique always worked for me when it was needed.
--earlgo
Deja Poo - The feeling you have seen all this crap before.
John Hasler
Re: Slitting saw
Post by John Hasler » Wed Mar 14, 2018 11:36 am
Again I wish I had a surface grinder. I need a .050" slit 1.5" into the end of a 1"x1"x2.5" part. I'm looking at making it in two pieces and then brazing them.
WJH
Re: Slitting saw
Post by WJH » Thu Mar 15, 2018 7:45 am
Shaper?
Sent from my iPhone using Tapatalk Pro
John Hasler
Re: Slitting saw
Post by John Hasler » Thu Mar 15, 2018 8:34 am
Shaper?
Another thing I wish I had.
stephenc
Re: Slitting saw
Post by stephenc » Thu Mar 15, 2018 9:00 pm
I've tried making slits with the shaper. My little Logan 8. Is fairly rigid for a small shaper but if you make one false move that thin little tool breaks real easy .
pete
Re: Slitting saw
Post by pete » Sun Mar 18, 2018 10:19 pm
One of my old machinist books briefly touches on slitting saws with some information I've not seen anywhere else but it seems to work in practice. They recommend for deep slots to get a cut line established first. Make a cut .050" or so first then each further cut no deeper than the tooth gullets as some else mentioned. They also state the recommended sfpm should be reduced to 50% - 60% of what normal hss cutting tools are listed at for the same material. So 50-60 rpm for a 4" diameter slitting saw in mild steel. My mill in back gear with a vfd will go that slow but many of the smaller mills just don't have enough torque left at those slow speeds. They don't detail exactly why, but my guesses are the first cut is light enough the blade shouldn't wander and that first straight slot helps to guide the next cut a bit. The slower than recommended surface speed is likely because so much of the tool is buried in the cut so heat is more of an issue?
