60° v block
earlgo
60° v block
Post by earlgo » Fri Sep 14, 2018 9:19 am
How would one go about making a 60° V-block for measuring the diameter of a 3 flute milling cutter? I'm thinking of something about 1" x 1" x 1" made from cast iron. I think I know how to machine it with a slitting saw, but then how is it ground smooth? Is there any other way except dressing a less than 60° angle on a grinding wheel? I am reluctant to waste that much wheel.
I am also reluctant to spend over $100 for a 60° micrometer.
--earlgo
mikeehlert
Re: 60° v block
Post by mikeehlert » Fri Sep 14, 2018 9:33 am
Just FYI, in a previous job we/I had a 60 degree 1" mic for a particular 3 flute job. It was a Starrett thimble 0.0001" carbide faced and when worn the cost to resurface the anvils resulted in a new mic. It was a lot more than $100 though.
Currently, this $201 is the cheapest on Amazon;
https://www.amazon.com/Fowler-52-211-14 ... micrometer
GlennW
Re: 60° v block
Post by GlennW » Fri Sep 14, 2018 9:39 am
I've considered doing the same and decided the way to go would be to dress a wheel that was wide enough to make a single pass to 30 degrees.
I have a sine chuck on my grinder so I would just set the chuck to 30 degrees and all would be good.
The relief groove at the bottom of the V would give you room to keep the side of the wheel from contacting the vertical side of the V during grinding.
Of course, you them flip the block 180 and finish it.
John Hasler
Re: 60° v block
Post by John Hasler » Fri Sep 14, 2018 11:47 am
Bolt two 60 degree blocks to a base.
earlgo
Re: 60° v block
Post by earlgo » Fri Sep 14, 2018 12:17 pm
Yes, I considered both of those solutions, but was hoping there was some other solution I didn't think of. Oh well.
Thanks for the replies.
--earlgo
tornitore45
Re: 60° v block
Post by tornitore45 » Fri Sep 14, 2018 12:48 pm
Please satisfy my curiosity:
Once you have a 60 degree V block how do you determine the diameter of the 3 flute tool?
Mauro Gaetano
in Austin TX
GlennW
Re: 60° v block
Post by GlennW » Fri Sep 14, 2018 1:03 pm
I was going to use it to check roundness of of shafts, etc.
A 90 degree V block will not detect tri-lobed shafting.
earlgo
Re: 60° v block
Post by earlgo » Sat Sep 15, 2018 11:13 am
tornitore45: The attached .pdf is the way I have always done it.
V BLOCK CALCS GENERAL RULE.pdf
v-block calculations general rule
(73.69 KiB) Downloaded 40 times
Feel free to correct me if I am in error.
--earlgo
tornitore45
Re: 60° v block
Post by tornitore45 » Sat Sep 15, 2018 1:49 pm
Thanks, as I suspected the specialty micrometers screws are not 40 TPI but divided by the factor M to give a direct reading.
Mauro Gaetano
in Austin TX
