Rotary table wear
leeko
Rotary table wear
Post by leeko » Sat Nov 21, 2020 9:00 pm
Hi all,
If a rotary table's motion is locked, would it be expected to see any wear from cuts made on stock held in a vise bolted to it?
I'm (hopefully obviously) talking about repetitive cuts over time.
Thanks in advance,
Lee
Sent from my SM-N960U using Tapatalk
Russ Hanscom
Re: Rotary table wear
Post by Russ Hanscom » Sat Nov 21, 2020 9:47 pm
Given that there is no relative motion between the parts, there should be no wear.
Post by Harold_V » Sun Nov 22, 2020 1:30 am
I agree with Russ, but unless there's good reason to leave a vise on a rotab, it's not really a good idea. It's all too easy to lose registration of the vise, to say nothing of the lost travel in the Z axis, as well as the lower setting of the cross slide handle of the mill. The added height may also offer a little less rigidity in the setup. All in all, you're better served to not mount the vise on the rotab unless there's a specific reason to do so.
leeko
Post by leeko » Sun Nov 22, 2020 10:30 am
Thanks both for the advice!
Lee
