Need a part
neanderman
Need a part
Post by neanderman »
Anyone have any ideas where to get one of these? Or what the name is? I've looked all over, and can't find one. It's for the Dual Drive. I suspect LeBlond may have one, but it is a commodity item that should be available somewhere! I don't have the actual specs, but can get them.
Ed
LeBlond Dual Drive, 15x30
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
Re: Need a part
Post by Bill Shields »
It is a lock washer for a od slotted nut used on a shaft with a keyway. Forget the exact name but have used 100'scofvthem to hold bearings on shafts
Tab washer? Or bearing lock washer. Google it
neanderman
Re: Need a part
Thanks, Bill! "Bearing lock washer" got a lot of hits, but most are spec'd per specific machine. More digging!
Ed
Atlas 618
rmac
Re: Need a part
Post by rmac »
McMaster-Carr has everything. Somehow the URL in the screen shot below doesn't work. Here's the one you need:
https://www.mcmaster.com/lock-washers/s ... ring-nuts/
Or Google for "spring lock washers for slotted bearing nuts" (without the quotes). You'll get lots of hits.
-- Russell Mac
Re: Need a part
Timken bearing tab lock washer.
Richard_W
Re: Need a part
Post by Richard_W »
Usually the old one has a part number stamped in it. So you just order the new one with the same part number.
Richard W.
neanderman
Re: Need a part
I'll have to look at it. I don't recall if it was marked. It is currently buried somewhere.
Ed
Atlas 618
neanderman
Re: Need a part
Okay, I found the original. It was in the last place I looked -- on the pulley shaft on the lathe. :lol: It does have a part number -- 3809 -- but that might be a LeBlond number.
I think I found one from McMaster that will work. All of $1.89. Now I just need to find a few other things to buy to justify the shipping!
Thanks for the help!
Ed
Atlas 618
