Measuring Tape Oddity
I have several import (Work Force) 12' tapes I use in the shop, around the house, etc.
The blade has the usual USA 16" stud spacing markings.
Just by chance while pondering a layout project on a new heavy wooden shelving unit
I noticed an odd tiny tick mark on the edge. Looking further they appear at regular
intervals. Question is, what do they represent?
My first thought was 1/2 and 1 meter intervals (on and inch rule), but the one mark
closest to a meter, 39.37" is about an inch short of that.
Anyone have a clue?
-=Rich=-
Anyone have a clue?
-=Rich=-
Happy Rails !
RichD
Colorado Midland Ry Ten Wheeler U/C
Kerr Stuart Wren NG 0-4-0 U/C
www.csppry.org
Imagination is your best tool.
RichD
www.csppry.org
Re: Measuring Tape Oddity
That is another spacing divided into 8 feet. I have seen it used on floor joist spacing. One less joist in 8 feet as compared to 16 inch spacing.
Can you post a picture?
Gregg
38 2/5 " or 19 1/5" per space. That would be 5 per 8 ft.
Wonder where that would be used?
...lew...
...lew...
if they are for metric refrence sheet of plywood are 90mm x 35 or 90mm x 45 with stud spacing at 450mm or 600mm.
will need to look at a tape measure if I can find one. hihi
And the winner is!
Jtrain probly has it right. 96"/5 = 19.200" exactly as marked. A tick is precisely on 8 ft.
An alternate joist or rafter spacing.
Learn something every day, Huh?
Happy Rails !
RichD
www.csppry.org
RichD
www.csppry.org
I've seen that used for stud spacing on interior non-load-bearing walls.
There is no stud, rafter or joist spacing that is 19.2 inches that I ever saw. There's 16 O/C and 24 O/C.
Ed P
SAVE A COW, EAT A DEER
The floor joists in my house are 19.2" spacing.
John
John
Are they timber or the laminated ones?
what interesting is finding instruction.
They are truss style joists.
If you go to most joist span calculators, 19.2" is one of the choices available for spacing:
http://www.awc.org/calculators/span/cal ... cstyle.asp
