Metal slivers in your fingers
- warmstrong1955
Re: Metal slivers in your fingers
Huh.....hear I am reading this....and I'm bleeding.....
(too late for the calipers.....)
Bill
Bill
This would often occur where I didn't have tweezers. I would get a piece of solid 12 gage wire 3" long and strip about 7/16" insulation from the ends. Bend it to a tight "U" and clip the ends with the same side of the wire clipper. With minor adj the jaws meet razor sharp.
A needle is generally my tool of choice but I have wondered if a super magnet would pull ferrous slivers.
Don Young
Generally it couldn't but EMRI and other technologies have opened new doors to using magnetism. Probably there is a way for this situation where the permanent magnet head would come to a cone. I don't know the right metal for that or calculation to where it would come to that point for extracting a small object. Somebody does. It would probably require an active field around it to contain and focus the pm field.
On the other hand, because I don't know, there is reason for phase shifting the attraction. Alternately resonating and breaking the sliver bond and extracting it.
Finally..... a rationale for buying a microscope!
I have almost as many tweezers as drill bits....what's with that...and any metal slivers I get are like cactus needles...they go in easy but tear flesh when attempting to pull out...already dreaming of a microscope..
I've had a couple MRI's and have been asked if I have had any metal in my body, jewelry, slivers, plates, pins, etc. My response has been, 'I'm a welder, it is very possible that I have a metal sliver, but none that I know of.' Then they tell me I can't have an MRI if there is any metal in my body, because the magnetic field could pull the sliver further into my body creating damage or infection. So I would say it is DEFINATELY possible but probably not economical.dly31 wrote:?..but I have wondered if a super magnet would pull ferrous slivers.
These work well:
http://www.ebay.com/itm/20X-Magnifier-M ... 3a9580fe68
unscrew and remove outer lens to reduce power
I keep a Sliver Gripper on my keychain so I can pull a sliver wherever I get one. Surprisingly good little tool.
http://www.leevalley.com/US/garden/page ... 2567,10434
Pete
Pete
- tornitore45
I tried a half earthed attempt with a disk drive magnet. No success.
Magnetic field closes in a loop around the magnet trough the air.
The permeability (think of the inverse of resistance for electric) of air is very low and the flux is weak even with a strong magnet. To work well a magnet should be part of a magnetic circuit made of ferrous material shaped like a C (better that a horseshoe) with the gap oriented perpendicular to the sliver.
I like Spro idea to use an electromagnet and pulsate the magnetic force.
I am a bit ashamed to disclose this but I fashioned a fairly effective tweezers from the crimped joint on a crate banding.
I cut out the clasp that clamp the crate band, flush on one side leaving two reeds of spring steel one the other side.
Bent the two reeds and ground to a small end.
I will buy the Lee Valley tweezers, they look very practical and portable.
Mauro Gaetano
in Austin TX
in Austin TX
Banding, near perfect. Another thing is they all can be filed or ground to a point. I would walk and my little tweezers would contact the grout between joints and leave no trace except forming a point.
It's not that it is new. Where I was at times, I cast an eye at the grout and see the marks of many work before my tweezer. I saw sharp edged tool marks of a blade in the rhythm of a walk, then a run. I saw too many marks . I never touched city grout or anyone's grout again ( except buying a structure where ...) Whole different phase.
Probably good but never better than fashioning your own by need at that time. The results of that speak.
Rather then spending long minutes/hours trying to grab the sliver with one of about 10 different tweezers, I just bite the bullet and dig out the scalpel and cut the skin which is over the sliver.
By squeezing the flesh, the sliver usually ejects itself, then a bit of antiseptic and back to work
You can buy blades sealed in foil, that fit an X-Acto handle.
I use # 11 blades which are long slender blades.
Rich
Rich
