Identify an air fitting
I got a new fog buster coolant system for my milling machine. The only problem is that my Millport milling machine seems to have a different air fitting thread than I've seen before. The fog buster wants to connect with a 1/4" NPT. However, the thread on the machine's air switch is slightly smaller. The desired thread is about 1/2" OD and is from 18 to 20 threads/inch, seemingly tapered. It looks a lot like a 1/4" NPT from first glance but it's not. I've been all over the web looking for this thing and so far don't even know what it's called. Someone told me it's a 1/2" 20, but even if that's true, I can't find anything on the web. If you know about this thing, please let me know. I would need to get an adaptor from 1/4" NPT to this. thanks much, rex
- warmstrong1955
Re: Identify an air fitting
Try here: http://www.eaton.com/ecm/groups/public/ ... 472120.pdf
NPT: .54 OD, 1/4"-18
BSP: .52 OD, 1/4"-19
Bill
Bill
I think I finally got it. It's a 1/2" 18 UNF I found it at http://mdmetric.com/4300/Pipe%20Fitting ... apters.pdf
Found the exact part I need to convert from 1/4" NPT to 1/2" 18 UNF
They directed me to Motion Flow Control in Portland where it's on will call now.
Hope it's right. thanks, rex
Bill, now I'm thinking that you might be right. I'll go ahead and pick up the one I found and if it doesn't fit; I'll check out the one you pointed me to. thanks much.
You had the right one Bill. Parker was able to find it for me. I had no idea there were so many thread types. This one happened to be on a Chinese air switch. Thanks much. rex
- warmstrong1955
Glad you figured it out!
That Aeroquip book is handy. With the book, a thread pitch gage, and a caliper, and you are off & running.
I got a 'thread identifier kit' when I attended an Aeroquip school in the 70's. Can't believe the price for 'em now.....
Mine should be worth even more......it's vintage....
http://www.amazon.com/Eaton-Aeroquip-Th ... B00C73GK48
BSP & BSPP is very common. I work with a lot of underground mining equipment, made in various countries in Europe, and it's most often what they use. Same is true on a lot of engines.
More often than not, China copies what they build....which includes the type of threads.
Bill
Bill
Oh wow! That price is insane. I suppose it's not everyday you find a ID thread gauge including BSP and BPP (etc), but really?
