Rust prevention & removal & lubricants - oils vs "WD40" vs natural fats (animal/plant)
Re: Rust prevention & removal & lubricants - oils vs "WD40" vs natural fats (animal/plant)
I run a dehumidifier in my workshop which works well.
I also recently got a can of this
https://www.amazon.com/Lear-Chemical-AC ... B000P1C8UO
When the side of the can suggests typical application being rotor heads then that's cool enough for me.
Sent from my SM-N920C using Tapatalk
- liveaboard
I have the same problem; near the sea, uninsulated workshop, even a porous roof.
But I don't think a single one of those US products are available here in Portugal [except regular WD-40].
I'm keeping my wood chisels in Tupperware. That works well.
When I lived in India I kept my tools in ammo boxes or air tight plastic barrels, but it's such a pain to dig things out and put them back all the time.
One trick that folks with gage blocks (Jo blocks) and pin gages do is rug lanolin on the surfaces then with a very clean soft cloth rub as much as possible off. The lanolin gets into the pores of the metal and becomes a moderate rust inhibitor. Lanolin can be had from Flexbar or other tool companies and it is not expensive for a tube. For tools in a tool box go to your pharmacist and ask for camphor in small bars. Put one or two (top and bottom drawers) in your tool box. This is also a moderate rust preventer.
Cary
Cary
- neanderman
Boeshield
Ed
LeBlond Dual Drive, 15x30
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
Atlas 618
Lanolin based products. 100% ECO and food grade. Works fantastic and can be applied under all weather conditions even under water.
WD40 ( Water Displacement formula 40 ) has almost zero lubricant, so you need to keep applying it. Waste of money. Lanolin is a bit more expensive but last for ages. Also great to waterproof leather shoes and boots.
- SteveHGraham
I love WD40 for removing stickers and machining aluminum. I like the fact that it evaporates. Which is one reason it's a useless lubricant and rust preventative.
- warmstrong1955
WD40 is a temporary thing. It has it's uses...many....
When I was working two weeks on & one week off, it worked perfectly for a rust preventative.
Before I hit the road to go back to work, I'd spray WD40 on my lathe, mill, drill press, etc.
When I came back, I could clean them off with a quick wipe, and go to work. Most of the WD40 was gone, seldom much dust collected on anything, and nothing rusted.
Use much of anything else, and you have a gloppy mess....with dirt in it, to clean. Wasn't the case with the WD40.
And for those with kids, or grandkids....it removes crayon marks from the walls....
Bill
Bill
- tornitore45
Never done more that that.Regular use with greasy .oily hands!
Mauro Gaetano
in Austin TX
in Austin TX
- juiceclone
strange as it sounds, I've had some success coating things with oil based wood stain. It's made to penetrate and then dry!!
If u don't mind messy, mix a bit of grease with gasoline and squirt that on. The gas penetrates, evaporates, and leaves behind whatever grease u used. Really good on control cables etc. because it gets into any space.
I am a big fan of fluidfilm.com. Fluid Film works well for me and penetrates metal
Formal education will make you a living;
Self education will make you a fortune.- Jim Rohn
"Opportunity is missed by most people because it is dressed in overalls and looks like work." Thomas Edison
