Cutting Oil darkens machinery surfaces
- SteveHGraham
Re: Cutting Oil darkens machinery surfaces
What's the alternative to pipe oil?
I prefer 'Anchor Lube" for tough work, including Stainless Steels. It is green, But must be wiped off immediately to prevent discoloration
There is also a clear oil product on the market that leaves no stain and I use it also. It is called "Butter Cut"
Rich
Rich
- SteveHGraham
It's funny, but Ridgid oil doesn't seem to be staining my tools. Moly-Dee turned my lathe saddle grey in a hurry.
- seal killer
All--
I never had stains on the mill table until I started using sulfurized cutting fluid. As others have said, they won't wipe off. However, I figured they were cosmetic and did not damage anything either in the short or long runs.
--Bill
--Bill
You are what you write.
I've had success using kerosine or thinner with scotch-brite; also paste wax gives results.
Cheers.
Cheers.
