Page 2 of 2
Re: Collet Clamping Nut driving me nuts!
Posted: Thu Mar 01, 2018 7:41 pm
by Cary Stewart
Well you did get a free one that works like the standard nuts. Do you really need a high-speed friction bearing nut on a 7" X12" lathe? It is a bit of over kill as the highest speed of your spindle is what - about 4000 rpm? A standard nut would have been quite adequate. Rego-Fix has a great reputation in industry. They are a little pricey for the general home shop machinist though.
Cary
Posted: Thu Mar 01, 2018 9:15 pm
by jouesdeveaux
Thanks, Cary. Good research. So it is definitely NOT appropriate for my Grizz 7X12! As far as pushing the the nut down on the collet until it snaps in: I'd have to weigh considerably more than I do (170) to get that to work. I'm really happy with the Hi-Q model REGO sent me.
IF ANYONE OUT THERE WANTS MY REGO HK/ER32 NUT, JUST LET ME KNOW. YOU COULD GET IT CHEAP :D
Posted: Thu Mar 01, 2018 9:21 pm
by jouesdeveaux
Cary
Quite right, Cary. I didn't know when I bought it at a garage sale that it was that advanced a tool. I general turn at about 800-1200 RPM. The one they sent me is just what I need-- perhaps even a couple of classes up. But it is sure nice to look at and to tighten down on my LMS collet chuck.
Gerry
Posted: Tue Mar 27, 2018 12:24 am
by p pfeiffer
Just some food for thought: The Myford M-2 collets are similar in that they have no eccentric. They use a tube and pin arrangement to compress the collet down so it can be inserted into the clamping ring (which threads onto the spindle nose). Maybe this ring had a similar arrangement. (???)
Posted: Tue Mar 27, 2018 6:12 am
by jouesdeveaux
Thanks for the suggestion, but... I don't see any signs of this. And my machine doesn't have a threaded spindle in any case.
