Cutting plastic
Re: Cutting plastic
johnfreese wrote: Sun Jan 20, 2019 12:24 am I hate turning plastic. I spent almost as much time untangling swarf as I did turning the parts.
If you fasten the tool properly and use the required speed and feed, the chips often come off in a long string, shooting above and beyond where you stand. When I face that issue, I put a garbage can where the chip falls and allow the cut to fill the garbage can. This device was machined that way.
It was made from black Delrin and natural ABS.
liveaboard
Re: Cutting plastic
Post by liveaboard »
As you will have a center hole, and presuming you have sheet material, a holesaw is fast and efficient.
25 years ago when I didn't even have a lathe to call my own, I made a tool for this; a short piece of 40mm rod to clamp in the lathe with a threaded hole, and a matching part with a hole to bolt through.
It doesn't deliver great concentricity, but it sure is fast for trimming rough cut disks to size.
If you need the hole well centered, it has to be corrected later.
SteveHGraham
Re: Cutting plastic
Post by SteveHGraham »
Harold_V wrote: Sun Jan 20, 2019 2:25 am This device was machined that way.
You never told us you played the bagpipes.
Re: Cutting plastic
SteveHGraham wrote: Sun Jan 20, 2019 9:29 am
That's because I don't. Not that I didn't try. I own a beautiful set (silver and ivory), but my musical talent extends only to playing the stereo, which I do quite well.
I have dyslexia, which is very troublesome, manifesting itself regularly when I do things like type. I can make errors at the rate of 60/minute on bad days. Imagine how that sounds when attempting to play a tune.
Strangely, dyslexia doesn't appear to manifest itself when I'm machining. For what ever reason, I'm quite good at operating machine tools. Wish my hand skills were half that good.
Jerry_H
Re: Cutting plastic
Post by Jerry_H »
Thank you, Harold. That is a very interesting tidbit of info.
Jerry
www.chaski.com
Re: Cutting plastic
Post by Bill Shields »
Know the definition of a Scottish Gentleman?
Someone that can play the pipes...but doesn't
earlgo
Re: Cutting plastic
Post by earlgo »
B C Comic
B C Comic
Sorry it is out of focus.
--earlgo
RSG
Re: Cutting plastic
Post by RSG »
LOL ^
