Machine tapping PVC sheet with small blind holes
Inspector
Re: Machine tapping PVC sheet with small blind holes
Post by Inspector » Fri Apr 12, 2019 10:58 am
My use of PVC (water/sewer pipe) is limited to a few pens. Cooking spray seemed to work as good as anything else I had when treading and cleans up easily.
Pete
Mark 2
Post by Mark 2 » Fri Apr 12, 2019 12:46 pm
Cooking spray! Who'da thunked? I'll give it a go and thanks.
Dave
Magicniner
Post by Magicniner » Tue Apr 16, 2019 2:18 am
I use Blaser Synergy 735 flood coolant for plastics and composites, it's oil free and Ph7.
Mark 2
Post by Mark 2 » Fri May 03, 2019 8:01 am
The project is done and the results are in. The winning solution, in my case, is a spiral flute tap as suggested by Harold and the hands down winner on cutting oil is.......drum roll here........cooking spray as suggested by Inspector! I resisted the cooking spray as just too far "out there" until I'd exhausted the other alternative cutting oils that I had on hand. I did try wax, Transultex & Accu-lube. I didn't try the suggested Blaser Synergy 735 due to cost. The cooking spray never failed to produce a very nice thread. Again who'da thunked? I used Costco Kirkland spray. Cheap, my favorite price right next to free.
Thanks to all that contributed to this thread. I will not hesitate to ask for advise in the future should I get "up against it".
Dave
Inspector
Post by Inspector » Fri May 03, 2019 8:38 am
:wink: :wink: :wink:
Pete
Post by Harold_V » Fri May 03, 2019 3:32 pm
In the interest of fairness, it was Russ Hanscom who first mentioned the use of spiral flute taps. I just agreed, having an understanding of why.
Mark 2
Post by Mark 2 » Fri May 03, 2019 6:07 pm
You're right, Harold. I'd forgotten the original source of the spiral flute suggestion. Thanks to Russ for that!
Dave
