RSG wrote: ↑Thu Jan 30, 2020 6:00 pm
Harold, pushing the tailstock is interesting, at first I thought it won't be aligned properly since it's not locked down but that really doesn't matter does it.
Alignment when reaming is always critical, but it's almost impossible to have what would be perfect alignment with a lathe tailstock. When new, they're high, and as they wear they become less than parallel, wearing more at the headstock end of the tailstock than the opposite end*, and end up below center over time. They are also often offset a small amount.
That said, in order for a reamer to find center without creating a bellmouth, I have a policy of gripping them by the shortest possible amount, so the cutting end is free to seek center. If you remove a few thou, the margin, being circular ground, will readily center the reamer in the hole under that condition.
You want to make sure that there's enough shank gripped to ensure it doesn't pull out, or spin during the cut. If you're interested in exploring this method, chuck up a reamer by about ¼" of its shank and see how it feels at the end. You should be able to move it about with just a little effort. If you can't, back off a little on chucking pressure, or grip by a slightly shorter amount. Note that the shanks of most reamers, like the shanks of twist drills, are not hardened, so the chuck jaws will indent, which prevents the reamer from spinning during the cut.
The one thing that can be troublesome with the floating tailstock is if you've left too much material to be reamed. In aluminum, if you're leaving ten thou or less, I can't imagine it being a problem. In tool steel, with a larger reamer, 15 thou may cause the tailstock to tip under cutting pressure. With that in mind, ensure it isn't a problem by keeping the tailstock ever so slightly restrained. Mine has a cam lock, so I just let gravity pull the handle down and that seems to be adequate, but then I've not done a lot of reaming.
*The tailstock wear I mentioned above is generally the result of routinely moving the tailstock before wiping the ways and oiling. While it may be moved away from the headstock on occasion, in my experience it's usually parked well out of the way, and must be brought towards the headstock when needed, thus the wear at the headstock end. For that reason, I NEVER move my tailstock without first wiping and oiling. It takes just a moment to do so, and ensures a longer useful life of the machine.
