Eye bolt rating
Re: Eye bolt rating
If I plan >250# per corner with a safety margin, I can almost guarantee that it will not end up on the floor.
BTW, I did find working load ratings for these common eyebolts, which are of course, far less than closed ring eyebolts. Hampton rates their eyebolt with a 1/2" thread at 350# working load. I am probably going to just cut lifting eyes out and weld them to the lifting cradle, so there are no eyebolts used at all, but thanks for the input.
Dave
Dave
- liveaboard
Re: Eye bolt rating
If you're in a hurry, bore holes in some nice steel strip, cut tabs off, and weld them to your square tube frame. You could do all 4 in 20 minutes or less if a drill press and saw are available to you.
In a pinch, really fast, flame or plasma cut the holes + all.
cheap, fast, strong, safe.
The only drawback is that the square tube will be more difficult to reuse than if drilled for a bolted eye.
Re: Eye bolt rating
Remember that eyebolts are designed for straight line loads. If the force is applied at an angle, such as with several slings without a suitable spreader bar, the allowable loading becomes much less.
Re: Eye bolt rating
Absolutely. The pull on the eyebolts, if used, will be straight up.Russ Hanscom wrote: ↑Tue Mar 17, 2020 8:22 am Remember that eyebolts are designed for straight line loads. If the force is applied at an angle, such as with several slings without a suitable spreader bar, the allowable loading becomes much less.
Dave
Re: Eye bolt rating
That's the beauty of having a CNC plasma table. Cutting things like this is as easy as pressing "R"! I am going to have a couple pieces of angle welded to the tube also, so there will be a few inches at each end that will become waste. It's possible, too, that the organization may want to purchase the lifting pieces in case of later moves, though I don't expect they'll need to move these again.liveaboard wrote: ↑Tue Mar 17, 2020 5:27 am If you're in a hurry, bore holes in some nice steel strip, cut tabs off, and weld them to your square tube frame. You could do all 4 in 20 minutes or less if a drill press and saw are available to you.
Dave
Re: Eye bolt rating
Our old company designs required that the lifting eyes, pad eyes as we called them, were welded to the equipment and were to be strong enough that one would hold the entire load if the other failed - made for some serious eyes - but never lost a load either.
Re: Eye bolt rating
That's how I tend to treat stuff. Overkill maybe, but I'm okay with that.
Dave
Dave
Re: Eye bolt rating
You can get next day shipment from McMaster Carr or the other major suppliers. Little more cost but fast service.
I agree with not using bent eye bolts for lifting. Nothing but an accident waiting to happen. I would bolt on a piece of angle iron drilled to make a lifting eye in a pinch. That I calculate its strength at least.
Rob
Rob
- liveaboard
Re: Eye bolt rating
And a few days after responding to this thread, I get this spam email; "Rigging Products-Lifting Eye Bolt"
Coincidence?
Coincidence?
Re: Eye bolt rating
The hills have eyes!
Re: Eye bolt rating
Ended up not using eye bolts at all. No time to go look for them. It also started raining, so I didn't want to drag the plasma cutter out to cut lifting eyes. So, I just bent up some 3/8" round bar and welded it to the ends of the tubing. Also welded up a spreader to hang the machine from. The round tube was galvanized so I ground the zinc off the outside, but you can see the residue on the inside. The welding was done in an open doorway.
Dave
Dave
Re: Eye bolt rating
I didn't think about it when reading the earlier posts, but I've done exactly the same thing with good result. I bent them with a cheap HF strap/bar bender. After I got done with them I cut them off and welded the bottom of the U onto my welding/fab table where they now provide holders for a selection of hammers used on the fab table.
Glad you got it sorted.
