Surface grinder hub ID
SteveM
Post by SteveM »
Does anyone recognize these hubs? They are believed to have come from a surface grinder.
The arbor threads are 3/8-24. The shaft where the wheel mounts is 3/4" diameter.
earlgo
Re: Surface grinder hub ID
Post by earlgo »
Every surface grinder wheel adapter I ever saw was for 1-1/4 or larger id wheels.
Might this be for a tool and cutter grinder? Although all the ones I have seen did not use an adapter.
I'd be interested in what you eventually find out.
--earlgo
SteveM
Post by SteveM »
The aluminum adapter on it brings it to 1-1/4".
John Evans
Post by John Evans »
tool post grinder ?
www.chaski.com
SteveM
Post by SteveM »
John Evans wrote: Sat Apr 18, 2020 10:28 pm tool post grinder ?
It had a 4" diameter diamond wheels on it, so that is a possibility.
earlgo
Post by earlgo »
"Might this be for a tool and cutter grinder? Although all the ones I have seen did not use an adapter."
Yike I must have forgotten my meds. I meant Tool Post Grinder as Mr. Evans suggested. I can't even blame autocorrect.....
--earlgo
