Chuckle!Bill Shields wrote: ↑Sat Jan 29, 2022 8:27 pm Drinking make little difference as we get older...unless you over do it
I'd have to agree! I'm in a constant state of confusion whether I enjoy a margarita (or scotch and water) or not.
Same here with me and my despicable mill drill. Aside from the annoyance factor, though, I never saw it as something to worry about. Am I missing something important? Pete?seal killer wrote: I do not know the X,Y backlash numbers. I am used to removing the backlash on the fly when necessary. It is fairly significant.
I've never bothered to try to measure the backlash. It's not good, though, on my (despicable) mill-drill--probably in the 0.020-0.030 range. To date I've dealt with the problem by always approaching the desired position from the same direction. In fact, I've never heard anyone suggest adding/subtracting a correction like you're talking about, but I have run into situations where doing that would have made things easier. So question: Assuming that the backlash is consistent along the length of the leadscrew, how close can I expect to get when turning the dial in the "wrong" direction and adding/subtracting a correction? Seems like that might be iffy.pete wrote: First it's a whole lot easier to mentally work with a few thou back lash and add/subtract your compensation than larger numbers when using the dials.
All good stuff that I hadn't thought about. Thanks!pete wrote: And light climb milling cuts of a few thou deep can still be done on non ball screw equipped mills to get a far better finish cut. Large amounts of back lash makes that a lot more error prone. And if you ever forget to set all the table locks on every axis your not using, the table is free to flop around like a dying fish within the amount of back lash on the nuts that's present.
You are correct. I worked in the machining industry for 26 years as a machine operator. In all those years, I never encountered anyone who worked that way. If for no other reason, it's not reasonable to assume the backlash is consistent, and it generally is not. That's due to wear of the screw.
I disagree, and that's from years of application. Excessive backlash makes no difference in the results of finish climb cuts. What makes the difference is the depth of the finish cut. Depth beyond that which can move the slide results in irregular finish and can even scrap the part by propelling the slide unreasonably. So long as the depth of cut can't propel the slide, the degree of precision isn't altered.pete wrote: And light climb milling cuts of a few thou deep can still be done on non ball screw equipped mills to get a far better finish cut. Large amounts of back lash makes that a lot more error prone.
I NEVER use the locks when taking finish cuts. They simply are not required, and they create problems that can be avoided by different work habits. That's particularly true if the dimension intended to be finished has a tight tolerance. Many machine tools lose position when locks are applied, due to the method of locking that is employed (usually bearing down on the gib). What works best is to take proper depth of cut for the finish passes by climb milling, with the slides in the relaxed (unlocked) state. By working in this method and knowing when to back off the slide, step (or notch) free corners when milling pockets can be easily created.And if you ever forget to set all the table locks on every axis your not using, the table is free to flop around like a dying fish within the amount of back lash on the nuts that's present.
