What is creep feed grinding?
... Is it a method of grinding or is it a type of grinding machine? -Doozer
Re: What is creep feed grinding?
Usually done with a wheel formed to the final shape of the part being made, or slotting hardened material.. Slow feed rate, high flow coolant and full depth in a single pass. Some "regular" surface grinders are capable of it, but more often machine made with that specific purpose in mind.
