Hole Transfer
- seal killer
Hole Transfer
All--
I find that I transfer a lot of holes in my simple work. I am not very good at it, though. SOMEWHERE, perhaps in a catalog or online, I read about a very simple tool that was like a screw with its head turned down to a point. They were used by simply screwing them into the part and then taping the part with a hammer to "punch" the hole locations in the workpiece with the point. They came in several screw sizes.
What are these things called?
--Bill
ps Today, the smith-wessonforum rejected my application for membership based on my Internet pseudonym; seal killer. I have used that pseudonym for years on firearms and non-firearms related forums. I am an atypical educator: I KNOW that political correctness is destroying our country. That is why I chose "seal killer" as my pseudonym. The smith-wessonforum chose to censor me because of my pseudonym, while allowing language that would NEVER, EVER pass on this forum of gentlemen. (Plus, many other firearm's forums to which I belong: Gentlemen are gentlemen.)
--Bill
You are what you write.
Here is another version of transfering a hole. These were originally used in die making for transfering a hole in a component inside the the dieset to the die set inself.
These transfere buttons are used for screw clearance holes but a few in the mix have shank sizes equal to the tap drill size for certain threads. They are made of tool steel and hardened with a torch. They can be repointed by grinding.
The threaded transfere screws are best but I never had enough lead time to order them before I needed them.
Jim
Jim
www.outbackmachineshop.com
Hole Transfer
This isn't the best way to a transfer holes but in a pinch I have used ball bearings that are larger than the hole and a sheet of transfer or carbon paper .
If you have enough balls the same size , you set the ball in the hole and place the carbon paper over it then put the part to be transferred to over that .
Then VERY easy and lightly tap / move / press down on the both work pieces . A very small and light mark will be left from the high point of the ball.
You have to watch so that the ball does not mar / distort the first thread or two. It's not as accurate as the threaded type ....BUT in a pinch it has worked .
Over the years I have obtained and keep about enough balls 8 or so in each of the most common sizes 1/8 - 1/2 and 3mm - 9 mm.
JerryL
JerryL
Take Care Have Fun Be Safe --Enjoy life and take care of your body --Life IS SHORT AND precious
Set the transfer screws just slightly above the surface and have layout die or a very clean surface for the marks to show. I use a scale and try to adjust until there is a minimum amount of light under it when it is sitting on the point of the screw. Test the part with the transfer screws by setting it on the flat surface and make sure that there is no "rocking" motion.
Then, hit it one time with a hammer but be gentle. Transfer screws can last a long time if treated properly.
- seal killer
Why the name seal killer
I tried several times to PM you but it wouldn't work.
Ok, I'm curious. Why the name "seal killer'.
I thought it meant you are hard on machine seals.
Or maybe you were a navy seal and good at killing.
Also, what type of educator. What do you teach.
As long as you are not a bear killer I see no problem.
Polar bears love seals. Very tasty.
Pooh Bear
Pooh Bear
Transfer screws
On my Heimann screws, the tip of the "case" is the hex socket that you use to screw the transfer screws into the hole. It's that little "nipple" on the end of the case. These are pretty old, but I think they're the same as the pictured ones.
BTW, I've always called 'em "Heimann screws" - kinda like "Kleenex", I just identified them by the brand - but is there a generic name for them ?
Pete in NJ
- seal killer
poohbear2767--
I retired October 2--just a few days ago--after thirty years in higher education. I am one of the very few conservatives in higher education. When I began to join forums that attracted my interest, such as shooting, I needed a pseudonym. Everyone had one, so I thought I needed one, as well. (This was quite a while ago.)
One of my main hobbies is shooting. I am not a hunter, however. I also have absolutely nothing against it, other than it is distasteful to me for someone to simply kill for sport. If I was HUNGRY, then I would be a hunter.
Anyway, as a conservative I am strictly anti-politically correct. It is not that I am rude or impolite, just the opposite is the case. But, to distort reality to such an incredible degree in the manner we have done in higher education is an attack on American freedom, itself. You see the results of that distortion every day, day in and day out.
So, when I joined my first firearms' related forum, the Desert Eagle forum, I adopted the pseudonym "seal killer." There already was a "deer killer" (avid hunter that eats what he shoots) and several "psycho"-this and "psycho"-that and "fifty"-whatever. If you had asked me this very same question on a firearms' related forum I would have responded totally differently with a complete fiction about protecting humanity from the new breed of killer seals that have evolved in the last 500,000 to 750,000 years. It is as funny as I can make it, after-all, humor is what makes us human.
My point with the Smith and Wesson forum administrators was that they rejected my application to join their forum based on my pseudonym ONLY. They did this after they knew my real name and e-mail address. However, if you lurk on that forum, you will find that they do not censor the language or much of anything.
Strange, to say the least. They are better off without me on their forum.
So am I.
On this forum, as on many others to which I belong, gentlemen (and the few ladies that might belong) are gentlemen and know how to treat one another, crazy pseudonym or not. Take a look at my tag line.
--Bill, aka seal killer
ps poohbear2767 and anyone else, I am really bad at checking my PM box, as well! My e-mail address is ringlord"at"sunflower.com
So am I.
Sounds like a man after my own heart.I am strictly anti-politically correct............to distort reality to such an incredible degree.......................is an attack on American freedom, itself. You see the results of that distortion every day, day in and day out.
I wholeheartedly agree.
Oh, and I strongly support the right to arm bears.
Pooh Bear
