Just cleaned out the sump on our cold saw and was going to refill it.
Any reason I can't run something like Mobil Omega or 766?
As it's used infrequently, the water soluble oil tends to cause the chips sitting in the sump to rust.
Coolant for cold cut saw
Re: Coolant for cold cut saw
You've been away for a long time. Welcome back!AAA wrote:Just cleaned out the sump on our cold saw and was going to refill it.
If you intend to make a change in coolant, might be a good idea to use a sump cleaner first. That will help prevent bacteria and other problems that may arise.
Hi Harold, yes sir. Don't get much time to frequent the forums these days, pretty much either sleeping or working!
I was lucky that the coolant that was in there was a synthetic one. It didn't smell one bit.
Since I do a lot of threading I've been running Mobil Omega or Mobil 766 on my lathes. This is an excellent sulphur based cutting oil. I was thinking that since a colt saw runs at such low speeds that this type of oil would work great and would stop everything from rusting. Just wasn't sure if the cold saw needed the water soluble stuff for dragging more heat away.
