Monarch lathe
Moderators: Harold_V, GlennW
John Hasler
Re: Monarch lathe
Post by John Hasler » Fri Jul 13, 2018 8:14 am
Replacing vacuum tube rectifiers with solid state devices is straightforward. However, if you are referring to the thyratrons (which are not vacuum tubes), replacing them with solid state devices would require replacing the entire motor control system with one of a modern design. I think that I would find that fairly straightforward as well, but I did make my living designing motor controls for some years.
The thyratrons are xenon filled. Not nearly as cool as mercury ones.
A modern modern motor control system to replace the tube one would essentially consist of a microcomputer and some IGBTs. Total parts cost less than that of a set of thyratrons. The original controls could be used, as could the original DC motor
whateg0
Re: Monarch lathe
Post by whateg0 » Fri Jul 13, 2018 9:21 am
The biggest problem that I have seen people run into when converting to a modern DC drive is that to get the full rated horsepower out of the motor, it is necessary to boost the input voltage. You need over 300VDC to drive the motor, and some are going above that. Not all DC drives will handle the higher voltage. Aside from that, it is pretty straightforward.
Dave
John Hasler
Re: Monarch lathe
Post by John Hasler » Fri Jul 13, 2018 10:19 am
That's why I assume that I would need to design a drive myself, and why I'd consider keeping the motor-generator.
In fact, of course, I will probably never even have the opportunity to touch a 10EE.
Mr Ron
Re: Monarch lathe
Post by Mr Ron » Sat Jul 14, 2018 2:18 pm
Originally I posted this out of curiosity, expecting a simple reply, but after reading all the replies, I can see why the Monarch 10EE is so coveted. Sounds like it could be compared to a Rolls Royce, Duesenberg or Bugatti. If I ever win the lottery, my first purchase will be a Monarch 10EE plus the services of Harold to teach me how to run it; all expenses paid, naturally.
Mr.Ron from South Mississippi
Re: Monarch lathe
Post by Harold_V » Sun Jul 15, 2018 1:58 am
I like the comparison to a Duesenberg. The car of my dreams. :-)
John Hasler
Re: Monarch lathe
Post by John Hasler » Sun Jul 15, 2018 10:27 am
A friend of mine had a Bentley from that era. Incredible maintenance hassle.
JackF
Re: Monarch lathe
Post by JackF » Sun Jul 15, 2018 11:14 am
Harold, mine too, next would be a Cunningham. Neither dream will ever be realized. :roll: :lol:
Jack.
SteveHGraham
Re: Monarch lathe
Post by SteveHGraham » Sun Jul 15, 2018 12:27 pm
I read Ian Fleming's novel, Casino Royale. In it, he bragged about James Bond's Bentley. He made it sound like a Lamborghini. Then I looked up the actual car.
It looks like Chitty-Chitty-Bang-Bang. I shouldn't be surprised. It turns out Fleming wrote that book. Picture the Beverly Hillbillies' truck, without the rocking chair. Ettore Buggati called it "the fastest truck in the world."
It was built in 1930 (the book was set in the early Fifties) and had a total of 175 horsepower. Miraculously, it reached almost 138 mph at some point; probably while going downhill. It performed poorly in races because the most British thing about it was its reliability.
Makes you wonder if Fleming drank too many vespers while writing about that car.
Really funny, picturing James Bond, rattling around in that ungainly, decades-old barge and thinking he was the bee's knees.
I had a 1978 Z-28 with 185 sad little horsepower, and it topped out at 124, with considerably less drag than the heavier Bentley. Makes you wonder about the Bentley's speed record! Maybe the guy who held the stopwatch received a free case of beer.
The 1935 Duesenberg was only 15 mph faster. Only.
JackF
Re: Monarch lathe
Post by JackF » Sun Jul 15, 2018 12:53 pm
In 1935, 152 mph? Duessy was pretty fast for a car off the showroom floor.
Jack.
SteveHGraham
Re: Monarch lathe
Post by SteveHGraham » Sun Jul 15, 2018 4:17 pm
I know which car I'd pick.
Mr Ron
Re: Monarch lathe
Post by Mr Ron » Fri Jul 27, 2018 2:05 pm
Bugatti's and Duesenbergs were incredible cars in their day. They were probably not the most comfortable cars and you needed arms like a truck driver to drive one. They were incredible in the way they were put together. The Bugatti "Royale" had hand fitted tapered bolts in it's chassis for example. They were the luxury cars of their time. No one else got close. All this cost big money when Ford, GM and hundreds of others were building cars for the masses. Many years ago, I read some books about the history of some of these fine machines and I can't remember all of what was said about them. I do recall when a salesman for Duesenberg drove down a street, put it into a 180° spin ending up at the opposite curb between two cars; my kind of car.
RCW
Re: Monarch lathe
Post by RCW » Sat Jul 28, 2018 5:10 pm
After reading the previous post about the 13ee, I looked it up on the 'net. It was lust at first sight! How many were ever manufactured?
And, Harold, what do you charge (beside travel costs) to teach ignorant but aspiring members of this forum? :D
--Bob
