simple qick change tool post
Moderators: Harold_V, GlennW
elewayne
Post by elewayne » Tue Mar 24, 2020 12:50 pm
There is a simple tool post I've seen mentioned by some guys name. its just a square block with a round post through it and a height bolt, a slot in the side to mount a tool in. anybody know what that post is called? I saw drawings and sizes somewhere but I cant find it again now. i don't really need the drawings, but I'd like to see them again.
Stefants
Re: simple qick change tool post
Post by Stefants » Wed Mar 25, 2020 8:05 am
They’re called Norman style toolposts. There’s an old patent I think and many references to build plans/videos that you can hunt up.
earlgo
Post by earlgo » Wed Mar 25, 2020 10:10 am
This is the one I built but I didn't know it had predecessors. This one fits a 10/12 in Atlas/Craftsman lathe compound.
tool post
There are dimensioned drawings if you wish. PM me and I will send them to you or anyone else interested.
--earlgo
pete
Post by pete » Wed Mar 25, 2020 9:12 pm
That drawing reminds me a bit of the Swiss made Tripan system Earlgo. Supposed to be as rigid as an Aloris or Dorian with the big advantage over them of having a lot more clearance when getting the tool post and holder in tight to the tail stock casting on our smaller lathes. http://anglo-swiss-tools.co.uk/tripan-tool-posts/ Yours should also do the same.
Lewayne
Post by Lewayne » Wed Mar 25, 2020 11:08 pm
Norman Patent was what I was trying to remember. Thanks guys.
earlgo
Post by earlgo » Thu Mar 26, 2020 10:04 am
pete: This tool block clamps the 5/16" or smaller tool direct without any other complications. The slots are 1/2" wide and 3/8" deep but that is so one can put a clamp pad between the tool and the screw tips.
--earlgo
drmico60
Post by drmico60 » Thu Mar 26, 2020 1:39 pm
