They said go big!
Moderators: Harold_V, GlennW
vair8
Re: They said go big!
Post by vair8 » Wed Nov 18, 2020 2:23 am
NP317 wrote:
Wed Nov 18, 2020 1:58 am
Be kind. It could be a periodic medical dosage issue.
Not trying to be rude:) read through some of his past posts and he has great info. Totally get it. Not a big deal.
SteveM
Post by SteveM » Fri Nov 20, 2020 8:16 pm
Nice find on the lathe. When I first saw it, I didn't think it had much swing, and then realized it's 9 freakin' feet long between centers! That thing is as long as both of my lathes and both of my mills side by side.
You should look up information on the King-Way tool used in measuring when you are scraping ways.
It measures not off the top of the v-ways, but on the sides of the V, which is much more accurate, as the top may not even be consistent from one end of the bed to another.
I think a platform using that principal would make a good level base for checking level.
There is a guy on youtube that built an "improved" version. Not sure about the improved part, but it appears to be easier to make that duplicating the original.
GlennW
Post by GlennW » Fri Nov 20, 2020 9:25 pm
vair8
Post by vair8 » Fri Nov 20, 2020 11:19 pm
Thats sweet! any suggestions on cutting out the tubing without a mill? I may have to. give that a shot. The other thing I bought was a couple of 123 blocks and figured maybe measuring from the flat might be better, not sure about that though. I'm also not convinced in the accuracy of the blocks.
Slapped a little stand together for my chucks tonight and emptied out an old toolbox base that I'm going to use for all my tooling. It's going to be a while before I get my garage organized again.
John Hasler
Post by John Hasler » Fri Nov 20, 2020 11:27 pm
You might be able to get away with using a piece of channel instead of tubing.
LouStule
Post by LouStule » Sun Nov 22, 2020 8:15 pm
Nice stand!
SteveM
Post by SteveM » Sun Nov 22, 2020 9:21 pm
If you can mount a pair of dowel pins at a proper spacing so that they are parallel, that might do it.
