Ball Turning Device
RSG
Re: Ball Turning Device
Post by RSG »
Thanks guys! I'll post a drawing of the part in the morning.
RSG
Post by RSG »
Sorry for the delay, here's the part I was talking about making. The inside is no issue as it could be machined first then screwed onto a bar of aluminum as a fixture to turn the radius. Anyone see any issues with this?
earlgo
Post by earlgo »
A ball turning device similarly constructed to mine would need a longer bar to support the tool holder, but it could work as the radial clearance up and down is enough.
I'd bet Mr. Howe's method would work better, with some adaptation.
--earlgo
RSG
Post by RSG »
Thanks Earlgo!
I'll have to work on something like that. I might find a way to incorporate my existing top slide to reduce the amount of time building it.
RSG
Post by RSG »
Conrad_R_Hoffman wrote:Pictures of mine here- http://www.conradhoffman.com/ballturner.htm
I find the hardest part of the whole thing is getting the tool position exactly right for a perfectly spherical ball. Not-quite-spherical balls are very easy.
I must have missed this earlier Conrad! Thanks, it's another viable option.
whateg0
Post by whateg0 »
My guess is that you'll need to have a long mandrel to mount the work on so that the part of the tool that rotates can be slid under it 6" closer to the headstock. Then run the TS end of the mandrel on a center and it should work.
RSG wrote:Thanks Earlgo!
you'll have be cognizant of the tool pressure. Hanging the tool 6" off of the compound may induce some chatter depending on how rigid your lathe is. Looks like Earlgo's version should be less susceptible, but it's still quite a bit of tool hanging over dead air.
WesHowe
Post by WesHowe »
Not just the vertical clearance is at play here. Convex curves with the "conventional" ball turner designs require the pivot to be closer to the spindle than the cut surface. For a larger radius that is a problem, as you either have interference between the chuck and the pivot, or you have to hang the work out a long way. For a 1" or 2" ball, this is not much of a problem.
RSG
Post by RSG »
Good points above^ and I am going to review the whole thing prior to moving forward. I have also designed an option that doesn't require a large radius and may just go that route depending on all the things mentioned above.
whateg0
Post by whateg0 »
WesHowe wrote:Not just the vertical clearance is at play here. Convex curves with the "conventional" ball turner designs require the pivot to be closer to the spindle than the cut surface. For a larger radius that is a problem, as you either have interference between the chuck and the pivot, or you have to hang the work out a long way. For a 1" or 2" ball, this is not much of a problem.
If the part can be flipped and doesn't require TS support, the radius tool can be placed at the TS end of the lathe. Alternatively, if the tool is made such that all of the support is done below the work, it will reside beneath it, just like the carriage would, but I guess that depends on the definition of "conventional" here.
