Mystery Knob on Logan Lathe tailstock
Moderators: Harold_V, GlennW
John in OH
Post by John in OH » Sat Dec 15, 2018 10:10 am
This question has probably been asked before, but I haven't been successful of finding an answer ...
I have an older Logan model 200 lathe and on the top of the tailstock there is a small solid "ball" about 5/16" diameter. It is a factory item original to the lathe and has a slightly snug fit in the tailstock and can easily be pulled out. It looks sort of like the ball end of a ball-and-socket connector. Anyone know the intended function of this ball??
earlgo
Re: Mystery Knob on Logan Lathe tailstock
Post by earlgo » Sat Dec 15, 2018 10:19 am
It probably is a dauber for a high pressure lubricant that used to reside in the well and was used to lubricate the dead center. If the lathe is old enough the lubricant was most likely white lead. I'll bet if you dug around in the well you'd find some dried 'stuff'.
--earlgo
John in OH
Post by John in OH » Sat Dec 15, 2018 2:23 pm
Following pics may help with identification:
John Hasler
Post by John Hasler » Sat Dec 15, 2018 2:38 pm
That's a dauber. Fill the hole with white lead and use the dauber to put a daub of it in the center hole when using a dead center. You're lucky to have a tailstock that still has a dauber. Usually they vanish for obvious reasons.
Actually, Neversieze works at least as well as white lead.
Post by Bill Shields » Sun Dec 16, 2018 7:38 am
now all you need is a can of white lead.....
WolframMalukker
Post by WolframMalukker » Sun Dec 16, 2018 3:33 pm
I use a product called CenterSaver-works way better than anything else i've ever found and doesn't have the lead in it.
Conrad_R_Hoffman
Post by Conrad_R_Hoffman » Fri Dec 21, 2018 3:50 pm
Never seen a real one; I made mine out of brass.
Conrad
John Hasler
Post by John Hasler » Fri Dec 21, 2018 4:23 pm
Same here. Then I lost it. I could buy a new one from Logan, though. Only $32.25.
Post by Bill Shields » Fri Dec 21, 2018 9:15 pm
I'll make you one for $29.95....
neanderman
Post by neanderman » Sat Dec 22, 2018 12:10 am
Ahh... Very interesting. My LeBlond has the socket and I've wondered what it was for. I thought maybe it was for holding a light fixture or something. :D
Ed
Le Blond Dual Drive
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
hoyt
Post by hoyt » Sat Dec 29, 2018 6:07 pm
Here are some links to tubalcain's videos on making a tailstock dauber for a Southbend and Logan, if you are inclined to make one for yourself.
https://youtu.be/08tc_fRY5ps
https://youtu.be/XR49xRCi59k
https://youtu.be/1JrJaOLONHI
fonzy
Post by fonzy » Fri May 10, 2019 11:27 am
I just made some tooling for my Logan 10" lathe, cut a few videos on it at:
https://www.youtube.com/channel/UCI22t7 ... subscriber
please like, comment and susbscibe to my channel, thanks. Fonzy
1969 Logan 1875 POWERMATIC 10" lathe, 1996 HF "MILL DRILL" Both with 20 year+ accumulative tooling!
Horz/Vert bandsaw AC/DC Stick Welder small wirefeed welder Oxy Acety Weld/cut ect.,
SEE MY INFORMATIVE VIDEOS AT http://www.youtube.com/user/alpho52
