Home made steady
Moderators: Harold_V, GlennW
liveaboard
Home made steady
Post by liveaboard » Mon Jul 08, 2019 6:07 pm
Ok, it's not pretty...
I have a job that just really needs a steady rest, so after 10 years of doing without, I finally put in a few hours and made one.
There are NO parts of any kind for my lathe; it's an orphan.
I haven't used it yet.
choprboy
Re: Home made steady
Post by choprboy » Mon Jul 08, 2019 7:31 pm
Looks good... Next job, chop the top half off, weld a hinge on the back joint and a bolt/nut on the front joint to reattach it. Now you can remove/swap work without moving the steady rest on the lathe or repositioning the rollers.
Post by SteveHGraham » Mon Jul 08, 2019 7:34 pm
Really nice.
Post by Harold_V » Tue Jul 09, 2019 3:19 am
Nice, indeed, but I highly recommend the alteration suggested by choprboy. Makes the steady a lot more versatile.
liveaboard
Post by liveaboard » Tue Jul 09, 2019 4:20 am
Thanks guys;
I know the factory made ones have the opening, but for now I'll keep it as it is.
I don't want to compromise the rigidity. The factory ones I've seen are made from much thicker section.
My material choice was carefully considered after scrutinizing my scrap pile...
rrnut-2
Post by rrnut-2 » Tue Jul 09, 2019 6:37 am
Looks nice! I was going to buy one for my 13" Clausing Colchester, but at $2400 its not going to happen. I may build one now.
Jim B
RSG
Post by RSG » Tue Jul 09, 2019 8:31 am
Looks great!
liveaboard
Post by liveaboard » Wed Jul 10, 2019 1:05 pm
First use today; it's finicky to get it adjusted right, and when the work heats up it gets too tight. But it works ok, I'm boring to fit bearings.
I have to make a wrench to get at the nuts, and it would be handy to have flats cut into the ends of the threaded rods so they can be held / adjusted while tightening the nuts.
Those are 18mm [about 3/4"] rods.
Googling the lathe today, I found a set of pictures from Czech republic of the same model but in pristine condition. And there is no image of a steady rest. Maybe they shipped without them.
And the one in Czech rep. has inch denominated dials; that surprises me. Inches in Europe??
Post by spro » Mon Jul 15, 2019 2:58 pm
Yeah, stuff like that makes makes one wonder. I was wondering how your wrench went but figured you already did it or modified the steady in some ways. I had thought about modifying a 12pt box end wrench by grinding out the end to let it pass around the threads. It looked like the channel taper would keep it from spreading.
Your steady looks solid enough and I'm impressed with it. Still, the threaded arms could use a key slot and the housing, inset keys.
liveaboard
Post by liveaboard » Tue Jul 16, 2019 4:01 am
Very true, but I have no machine to make keyslots.
Also, I rarely need the steady; so time spent with the finicky adjustments has to be weighed against time spent working on the tool. If I spend 10 hours improving it, will it save me 10 hours?
