simple qick change tool post
Moderators: Harold_V, GlennW
elewayne
Post by elewayne » Tue Mar 24, 2020 12:50 pm
There is a simple tool post I've seen mentioned by some guys name. its just a square block with a round post through it and a height bolt, a slot in the side to mount a tool in. anybody know what that post is called? I saw drawings and sizes somewhere but I cant find it again now. i don't really need the drawings, but I'd like to see them again.
Stefants
Re: simple qick change tool post
Post by Stefants » Wed Mar 25, 2020 8:05 am
They’re called Norman style toolposts. There’s an old patent I think and many references to build plans/videos that you can hunt up.
Sent from my iPhone using Tapatalk
earlgo
Post by earlgo » Wed Mar 25, 2020 10:10 am
This is the one I built but I didn't know it had predecessors. This one fits a 10/12 in Atlas/Craftsman lathe compound.
tool post
There are dimensioned drawings if you wish. PM me and I will send them to you or anyone else interested.
--earlgo
pete
Post by pete » Wed Mar 25, 2020 9:12 pm
That drawing reminds me a bit of the Swiss made Tripan system Earlgo. Supposed to be as rigid as an Aloris or Dorian with the big advantage over them of having a lot more clearance when getting the tool post and holder in tight to the tail stock casting on our smaller lathes. http://anglo-swiss-tools.co.uk/tripan-tool-posts/ Yours should also do the same.
Lewayne
Post by Lewayne » Wed Mar 25, 2020 11:08 pm
Norman Patent was what I was trying to remember. Thanks guys.
earlgo
Post by earlgo » Thu Mar 26, 2020 10:04 am
pete: This tool block clamps the 5/16" or smaller tool direct without any other complications. The slots are 1/2" wide and 3/8" deep but that is so one can put a clamp pad between the tool and the screw tips.
--earlgo
drmico60
Post by drmico60 » Thu Mar 26, 2020 1:39 pm
whateg0
Post by whateg0 » Tue Mar 31, 2020 12:40 pm
Why is this considered a QCTP? Doesn't look like it would be very quick to change a tool Maybe quicker than an Armstrong?
Dave
Stefants
Post by Stefants » Tue Mar 31, 2020 12:45 pm
whateg0 wrote:Why is this considered a QCTP?
Dave
I think anything that allows you to turn one bolt to release the tool that’s there, drop on another without having to fiddle with center height, then get back to turning is “quick” (in comparison to the previously ubiquitous lantern style or quad block holders). So this counts in my book :)
