Page 1 of 50
Show us your lathe!
Posted: Sun Apr 11, 2010 7:15 pm
by AllThumbz
Ok, here we go...to kick things off, let's see what type of lathe you use in your shop....
Here is mine as received before I disassembled it to work on:
and here it is in my shop disassembled being worked on:
Let's see yours!
Nelson
Re: Show us your lathe!
Posted: Sun Apr 11, 2010 8:50 pm
by BigBob
How do you attach photo... I have on hard disk.
Posted: Sun Apr 11, 2010 9:15 pm
by bedwards
Here are as found and after pics of my Sheldon:
be
Posted: Sun Apr 11, 2010 9:47 pm
by GlennW
In it's daily trim. Nardini, made in Brazil.
Posted: Sun Apr 11, 2010 10:36 pm
by Harold_V
BigBob wrote:How do you attach photo... I have on hard disk.
If you'd like to have the Chaski board host your picture, all you need do is click the Browse button, found below the box in which you compose your post. The blue line above the Browse button says Upload Attachment, assuming you are using subsilver as your board choice.
When you click the Browse button, the software will then allow you to go to your stored pictures. Click on the one you choose to post, than click Add the file. Done. You can add more pictures by clicking the Browse button once again. Take note that you can assign the pictures to display in the order of your choosing, or you can even place them within text.
If you prefer that pictures be hosted off the Chaski site, please insure that they display no larger than 800 pixels in width, to avoid spreading text off the screen. Size is not a consideration if you post only the link, so pictures do not run automatically.
Posted: Sun Apr 11, 2010 10:55 pm
by BigBob
Thanks, missed the 'upload attachment' below the reply. Here's a photo of my Colchester 13 x 36. The extra turret tailstock is still on at time of photo and since removed and stored. Have the high speed tap attachment (not tried yet), three steady rests. No taper attachment, so advise on where to buy or how to make would be appreciated.
Posted: Mon Apr 12, 2010 4:40 pm
by Russ Hanscom
There are several recent previous threads on installing tapering attachments. Most recently, several persons have obtained new Jet units, old stock, for prices around $200. They appear to be very good quality. I installed one on a Harrison 600 AA, including making a telescoping crossfeed screw.
Posted: Mon Apr 12, 2010 4:51 pm
by AllThumbz
Would love to see some photos of that Russ...
Nelson
Posted: Mon Apr 12, 2010 4:54 pm
by Russ Hanscom
The thread on taper attachments has photos, I will try to find the specific thread.
Posted: Mon Apr 12, 2010 5:00 pm
by Russ Hanscom
Here is my Harrison 600 AA, which replaced a Sheldon 13 x 36. This is a low hours unit from a lab and is well equipped.
Posted: Mon Apr 12, 2010 6:49 pm
by jim rozen
A small bench lathe, one I've recently set up again in my basement shop (it was languishing in a crate for quite some
time) with a VFD drive. Lots of fun to run:
Seven inch swing pratt and whitney bench lathe, it takes 3C collets right in the spindle. The toolmaker's
compound, that's not by P&W, though.
Jim
Posted: Tue Apr 13, 2010 9:32 am
by S.Turf
Another satisfied Nardini owner.
