Grizzly MT5-to-5C adapter
Since this has come up in several posts/forums, I thought I'd post this info, fresh from Grizz tech-support today:
"The collet adapter that adapts the spindle bore from a MT #5 taper to accept 5-C collets is available by part number. The part number is P4026001 Collet Adapter priced at $30.00 plus shipping and handling. The use of a drawtube or drawbar will still be necessary for the collet adapter to remain centered and stable in the spindle bore."
- mechanicalmagic
Re: Grizzly MT5-to-5C adapter
I wish that post had come 10 years ago, before I bought my collet adapter for ~$300....tlfamm wrote:Since this has come up in several posts/forums, I thought I'd post this info, fresh from Grizz tech-support today:
Dave J.
- coal miner
Good job ,tlfamm ! I knew mine came from Grizzly , but darned if I could find the part # . CRS for sure .I made the draw tube from DOM tubing and added the thrust bearing for ease of operation . First time cutting internal threads . Handy as a pocket on a shirt . Use it almost as much as the 4 jaw .
The more I learn , The more I don't know !
coal miner wrote:Good job ,tlfamm ! I knew mine came from Grizzly , but darned if I could find the part # . CRS for sure .I made the draw tube from DOM tubing and added the thrust bearing for ease of operation . First time cutting internal threads . Handy as a pocket on a shirt . Use it almost as much as the 4 jaw .
Pictures, pictures, pictures ...
- coal miner
Don't have any pics other than the other post . Do a Google or search this site for making a drawbar for 5C . Should get some hits to use for ideas , dimensions and pics . If not , let me know and I'll see what I can come up with .
Ah - I rediscovered Chris Long's photos of his shop-built collet-closer, available on this page:
http://www.the-long-family.com/tooling.htm
It was he who first mentioned the Grizzly MT5/5C adapter to me last summer ...
coal miner, or anyone else...can you tell me what the diameter of the big end (behind the flange)of the MT5 to 5c grizzly adapter is?
I have a lathe with a MT5 hole and its diameter is 1.733". I bought a adapter off ebay a few years ago and it was too small for my bore by about .100"
and yes, it was a mt5 to 5c adapter.
I solved my immediate problem by picking up a jacobs 900 hub with the rubberflex collets for a good price. but the right adapter would let me cobble up a Royal quick release setup that I have to round out my tool choices.
In theory, a MT5 shank should be about 1.748" on the big end.
Perhaps your adaptor was "modified" prior to being sold on eBay.
Not that that would ever happen!
I have a question for those of you who have the adapter. How far does the whole unit stick out from the spindle nose? I have a early 80's Jet 12 x 40 PY. If the collet sits very close to the end of the spindle, I don't think I have enough movement in the carraige to reach it. Wow, English really is my first language! I am trying to say that I can not get a cutting tool to reach the spindle. I can't move close enough to the head stock. I am hoping that the adapter sticks out about as far as a chuck does. Hope this make sense. Thanks Scott. ps a picture would help.
yes my spindle has a mt5
Tools4cheap also sells the adapter; see picture (with measuring rule):
http://www.tools4cheap.net/proddetail.p ... =5cnosemt5
- coal miner
Just put the 4 jaw SB back on this morning or I would take a pic . IIRC the 5C adapter outer end is around 1" to 1-1/2 " from the face of the D1-4 mount . I have to watch when I work close to the spindle nose but there or several ways around this . Changing the angle of the compound on the cross slide , advancing the compound towards the end of its travel , and sliding the QCTP to the left side of the compound mount . Any or all of these changes should let you get close to the spindle nose . I am able to work right up next to the collet on my GH 14x40 Jet lathe w/ mt5 spindle . As you stated the carriage will hit the gearbox housing and then you could have a big prob . Th carriage hitting the headstock will create a shearing action on the feed screw and thank goodness I have a shear pin on mine . Don't ask me how I know . I do have a supply of brass and aluminum ones .S.L.Schroder wrote:Y. If the collet sits very close to the end of the spindle, I don't think I have enough movement in the carraige to reach it.
This adaptor (P4026001) has gone up in the intervening years from US$29.50 to US$122.50 (and is only obtainable in the US). No longer an economical proposition, I'd say.
