reverse tumbler gear speed reducer for G0602 lathe
norman
Post by norman »
I've built a speed reducer for this lathe and a reverse tumbler gear set. I have it posted on another forum. With the moderators permission I could put up a link to the forum.
Norman
Here is the speed reducer slows the spindle down to about 58 rpms for easier threading I hope. Made from casting for the reducers frame and 3 timing gears from a small engine my first attempt at building a speed reducer.
http://www.youtube.com/watch?v=qopnUPtaAnU
ken572
Re: reverse tumbler gear speed reducer for G0602 lathe
Post by ken572 »
Norman,
Check your messages.
Ken. :)
One must remember.
Ken.
ken572
Post by ken572 »
norman,
Thanks for your help. :wink:
You did a very nice job on this .pdf below.
http://www.projectsinmetal.com/wp-conte ... -Plans.pdf
Thanks Again.
Ken. :)
One must remember.
Ken.
norman
Post by norman »
Ken, I didn't do the PDF I did the photos and the white board drawing/sketches and one of the members put the pdf together his name on the forum is" Blame" my hat is off to him for the help.
norman
Post by norman »
I have an idea for an easier to make speed reducer. That will still fit inside the lathe cover,plus make it so a guy can change the speed some. I drew up a rough sketch in deltacad and promptly lost it, not knowing what I was doing trying to send it by email. Now I just have to build it and redo the plans.
Good news!
Blame got my email of the drawing and put it on the speed reducer post in "projects in metals" forum
norman wrote: With the moderators permission I could put up a link to the forum.
Not a problem! Please do so.
norman
Post by norman »
Thanks Harold
here is the speed reducer for the G0602 lathe link this could be used on many of the imported lathes:
http://www.projectsinmetal.com/forum/ge ... d-reducer/
Here is the reverse tumbler for the G0602 lathe link:
http://www.projectsinmetal.com/forum/ge ... for-g0602/
Norman
