Some time ago, I posted a YouTube video regarding one of my first thread cutting efforts. The topic here on the forum was "Cutting a 3/4"-10 Class 3A Thread in Aluminum". Yesterday, a gentleman left a comment with thread cutting guidance on my YouTube page. Because of my inexperience, I can't figure out why what he is telling me is better. Will you explain it to me?
Thanks.Bill your thread is wounding on you if you are just learning , learn the right way don't get into bad habits right from the start, run all but the last .020 of depth with your compound and finish it with the cross slide then you will get a true angle cut and you will not get a taper in your thread millions of threads are cut this way and I think it is the only way ,but I have been doing this for 52 years so what do I know ,but everyone thinks you should start and finish threads with the compound try it the other way you will like it ,also I have cut metric threads on my 709 and you can't disengage your split nut so just step on the brake to stop it then reverse it to back you carriage back to the beginning also get away from that water you use for coolant it will contaminate your lower gears in saddle and really give you some problem's down the road I use cutting oil in my coolant tank believe me water and oil don't mix sooner or later it will get into your oil and screw up your clutches ,I have always keep my hand on my carriage wheel to take up the slack when threading and start your threading tool back a little more some day you will hit the wrong number or line and you will not have enough time to react on your mistake and scrap the part.
--Bill
