Robust
Moderators: Harold_V, GlennW
Russ Hanscom
Robust
Post by Russ Hanscom » Fri Jul 19, 2019 8:23 am
Nice having a robust mill, a Gorton 1-22.
This is a Janney coupler, the first successful automatic coupler. Drilling out 1 1/4" dia rivets so the shank can be replaced.
Over 5" of metal to go through and as the quill travel is 4", and it takes extra head room to change bits, a fair amount of up and down for the knee is needed. The feed that died moves the knee through a 3:1 ratio drive; it was over 15 years old.
The 12" riser helps a lot too.
earlgo
Re: Robust
Post by earlgo » Fri Jul 19, 2019 9:09 am
Have you considered taking up model trains as a hobby? :lol:
--earlgo
Russ Hanscom
Re: Robust
Post by Russ Hanscom » Fri Jul 19, 2019 9:38 am
I have, I model in NG 1:1 scale! I have some 1/8 scale castings but rarely get to them.
spro
Re: Robust
Post by spro » Fri Jul 19, 2019 10:50 pm
My comment is towards the massive weight and the work to drill out those rivets. It didn't help that the power feed had blown out. Remarkable work required and "Robust" is certainly the word. Sometimes I use it as comparisons to like things but this scale of robust is a different level. Neat dedication.
