This next one is for all the guys in the Rockwell group that were discussing
how to repair the aluminum gear for the head tilt with a new keyway.
I used a steel ring with a 3 inch ID for a demo mock up, so just slightly smaller.
Raised it on 1 inch blocks and clamped. Pic 3 shows just enough clearance to complete
the cut.
The attachment is a Bridgeport No.2 right angle head which is designed for a
2.563: dia. quill and has been bored out to 2.95" and has a drive shaft extension
that is 3/4" dia.
A No.4 head could also be adapted would still need and extension drive shaft
but no boring just a steel or aluminum sleeve to adapt from 3.376" to 2.95"
A No.2 head is m ore versatile it has a 1 inch longer reach.
These heads can be bought used on Ebay. Sometimes you can find a deal.
The 1/4 inch endmill has a shortened shank section.
There are specialized endmills out there with even shorted cutting flutes that
would allow access to even tighter situations.
ROCKWELL 21-122 milling machine REBUILD
Re: ROCKWELL 21-122 milling machine REBUILD
Well this is the next accessory that I made up for the mill.
A faceplate and a topslide adaptor bracket to be able to
turn and bore items too large to put on a faceplate on my
Chipmaster. Face plate on that is 10-7/8" and 11-1/2 " swing
The face plate here is 12-1/8" and can swing over 19 inches x
4-1/2" deep. I found the faceplate on Ebay for 100 to 125.00
and the machined it and made an adaptor brkt for the horizontal spindle.
Not that you would put a solid hunk of metal that large
on the faceplate. But there may come situations where an awkward
shaped part may be well served with larger faceplate turning ability.
By de-rating my speeds on the horizontal spindle I have a 38 or 39 rpm
low speed, well suited to spinning larger items.
The topslide comes off my Chipmaster with 2 nuts and bolts onto the
adaptor plate and then onto the mill table with 4 bolts.
There are 2 alignment pins to register the 0 degree point.
While I have the mockup in situ to showcase this accessory,
I think I true up the faceplate .
- Attachments
- P1040467.JPG (68.72 KiB) Viewed 63 times
- P1040468.JPG (82.79 KiB) Viewed 63 times
- P1040469.JPG (73.22 KiB) Viewed 63 times
- P1040470.JPG (74.07 KiB) Viewed 63 times
- P1040471.JPG (77.65 KiB) Viewed 63 times
- P1040472.JPG (69.22 KiB) Viewed 63 times
Creative!
Well the faceplate is trued up.
When I was checking fit and runout I got .055 on the face
and .015 on the circumference.
Seemed way too high considering the back of the faceplate
was turned at work on a lathe mounted to a faceplate that
was true.
So I started by remov ing the drive key and remounting it.
That got me to .030 and .014".
I thought about that and decided to take off the faceplate
and face the end of the spindle.
That got me to .011" and .001 on the circ.
Couple skim cuts and the face was true to within .0005"
and the .001 on the circ. not worth worrying about.
was true.
