Glue one of these to the underside of the ways of your lathe and another somewhere low down on your mill:
https://www.amazon.com/Kats-22400-Watt- ... B000I8XDAS
Bare Metal Protection
- tornitore45
Re: Bare Metal Protection
If I was after the light an LED may make sense, but the reddish light off the bulb is a byproduct of the "heater".There are those out there that want you to replace that bulb with an energy-efficient LED.
I designed LED ballast for a living, and I can tell you that while the LED may last 1/2 million hours the electrolytic capacitor in the ballast will fail much sooner.
Economic, competitive and the lack of integrity of our industries force the designer to specify a severely under rated capacitor that is known to fail prematurely. A similar situation happens for CFL, but is a toss up whether the electrolytic or the filament fails first.
I have no idea of the carbon footprint comparison between an uderpowered 60W light bulb, a brand new LED (assuming it was a suitable replacement). I have an hunch that the Mitsubishi AC is the worst, but keep me cool.
Steve I do not mean my answer as a put down, even if it sound so. You pushed one of my buttons.
Mauro Gaetano
in Austin TX
in Austin TX
My problem is similar....incredible condensing humidity in New Orleans. Basically tropical weather.
I have found Lanolin works best. You can buy Fluid Film which is Lanolin based. Or...do what I did. Go on Ebay and find pound of raw Lanolin. And then heat it up and mix with mineral spirits and oil. It works great. Best rust prevention I have run across.
FWIW....I found this a while back in some forum. copied it and saved it. Its a recipe for it.
Fluid film
The original formula is (by volume) 3 Lanolin, 3 Mineral oil and 7 Mineral Spirits [paint thinner]
The formula was available on the MSDS before the current owners bought FF.
There is a superior formula that offers better flow in cold. FF does not offer that.
Fluid film
I bought one of those Sure Shot sprayers and mixed up some ATF, kero, and bees wax. I tried that this past winter and all seems fine. Of course most everything already has a patina. The few new bits still shine though.
Not all LED drivers contain electrolytic capacitors.
