Steel Square 1903 (312p)
This is where bits of wisdom will be stored, a frequently asked question section with answers.
Moderators: Harold_V, WJH
ken572
Post by ken572 » Sat Apr 25, 2015 8:32 am
(ALL) :D
Interesting Read.
A practical treatise on the Steel Square,and
its application to everyday use 1903 (312p)
https://archive.org/download/practicalt ... 01hodg.pdf
Ken. :)
One must remember.
Ken.
EricM
Re: Steel Square 1903 (312p)
Post by EricM » Tue Mar 10, 2020 6:10 am
liveaboard
Post by liveaboard » Wed Mar 11, 2020 6:16 am
I noticed one of my construction squares wasn't quite square; upon checking, none of my squares were square.
I went to a wholesale shop that had a retail counter, he had a machinist square, heavy thing with ground surfaces. We went to the back and I used the good one to check a shelf full of moderately [NOT cheap though] priced builders + carpenters squares.
I found 1 or 2 that was good.
He told me he'd had the machinist square in stock for years and let me have it cheap.
I bought a Russian machinist square at a flea market;, it was unblemished and quite square. Treasure!
I keep the European one in a sealed box [they're rust prone].
For large format work, like squaring the ends of plywood sheets [not square from the factory] I sometimes make one on the jobsite with a tape measure and a little math.
