How to Run a Lathe
This is where bits of wisdom will be stored, a frequently asked question section with answers.
Moderators: Harold_V, WJH
johnfreese
How to Run a Lathe
Post by johnfreese » Thu Feb 02, 2017 11:23 pm
South Bend "How To Run a Lathe"
johnfreese
Re: How to Run a Lathe
Post by johnfreese » Thu Feb 02, 2017 11:27 pm
I tried to attach the PDF but ir didn't work.
SteveM
Post by SteveM » Fri Feb 03, 2017 9:33 am
johnfreese wrote:I tried to attach the PDF but ir didn't work.
You can get the 1928 version at Vintage Machinery:
http://vintagemachinery.org/pubs/detail.aspx?id=5795
johnfreese
Post by johnfreese » Fri Feb 03, 2017 8:47 pm
I have the 1956 edition. I doubt that they changed much.
SteveM
Post by SteveM » Fri Feb 03, 2017 11:05 pm
johnfreese wrote:I have the 1956 edition. I doubt that they changed much.
For most of what we are doing at the level at which we are doing it (not quality, but quantity - we aren't production shops) the older versions of HTRAL are probably adequate.
They won't cover carbide inserts, but the operation of the lathe is pretty much the same.
johnfreese
Post by johnfreese » Wed Feb 08, 2017 2:42 pm
I have founf that online versions of machining texts from the early 20th century pretty helpful. They show machine setups you will never find a modern shop.
